Best way to keep an amp cool
Old Aug 18, 2006
Draven2's Avatar
small cities make me poop my pants
Draven2 is a jewel in the roughDraven2 is a jewel in the roughDraven2 is a jewel in the rough
Damn thing keeps overheating and I'm tired of having to ride with the back seat down and the window open all the time. Any ideas?
Old Aug 18, 2006
diskreet's Avatar
The best way to keep an amp cool is buy one that doesn't overheat (Kenwood, Infinity, JL, etc)
Otherwise give it as much ventalation as possible and make sure its not up against anything.
Old Aug 18, 2006
4Saris's Avatar
4Saris is an unknown quantity at this point
Buy one with a fan?
Old Aug 18, 2006
bluestreak's Avatar
bluestreak is an unknown quantity at this point
I bought an additional fan, basically a computer fan and hooked it up to power supply - just an idea
Old Aug 18, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
ehhhhhh ehhhhh buy a bazooka amp that has a water cooling system?
Old Aug 18, 2006
diskreet's Avatar
Buying a PC fan is a good idea. Many people do that. Works well.
Old Aug 18, 2006
MegaHurtz's Avatar
Put it in a location with better circulation, face up so that the heatsink is most effective. You can also mount cooling fans to push air onto it and that will help as well.
Old Aug 18, 2006
Draven2's Avatar
What can I say, I bought the rockford amp and Kicker soloberic for only $360 Wiring and all.
Old Aug 18, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Talking
Elaborate on this for me...
All I have to do is tap into my power wire & ground the fan correct.
Maybe a switch in the cockpit to turn it on & off???
Also I’m real high now but,
Aren’t commuter fans on AC currant & cars run off DC currant?
Or are they both DC? Or is it AC?
Elaborate for me electrical gurus!
Old Aug 18, 2006
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
computer fans are dc, and run on 12v, so our cars will be fine with them, I'm not sure if it would be a good idea, but anyone think you could wire the fan into the remote wire? it wouldnt be too much draw off of the deck
Old Aug 18, 2006
ex2k3's Avatar
diamonds she will pretty much have to
ex2k3 is a jewel in the roughex2k3 is a jewel in the roughex2k3 is a jewel in the rough
my friend added a fan to his amp, he cut a hole in the amp casing and mounted the fan in the hole, then he powered the fan by connecting the wires to the ground and remote wire terminals inside the amp. His looks ghetto as hell but you can make it look good if you spend more time than the 20 minutes he spent on it.
Old Aug 18, 2006
02BLKCIVIC's Avatar
**** hook it up to its own 12V supply like the battery & have a switch hooked up to the power supply too turn it off.
what do you think?
Old Aug 18, 2006
booba5185's Avatar
that'd work fine, just make sure you fuse it, you could also hook up up the the +12v on the cig lighter, it's only on with the car is
Old Aug 18, 2006
02BLKCIVIC's Avatar
**** im gona go price computer fans now...
ya good idea on the fuse too!
see ya booba.
Old Aug 18, 2006
booba5185's Avatar
less than ten bucks, they come in 60 or 80 mm, and since your stoned, they have led fans that glow ooooooooooooo
Old Aug 18, 2006
spoonEM's Avatar
omgwtfbbq mod.
or just get an amp that is designed to handle the sub. i.e. dont get a sub that is more powerful than your amp, that will cause overheating. Im running a JL audio 500/1 for my premier sub and that doesnt overheat. The amp is alot more power, but I just have the gain down a little bit.
Old Aug 18, 2006
mishqua's Avatar
mishqua is an unknown quantity at this point
Its real easy instead of running the remote to the amp it self , get a relay run the remote to the relay. Hook up the power wire ground the relay your done. Now u can do all sorts of stuff, I did this so I could run my fans and my amps, Later on I will use it for the cathode lights. hope that helps
Old Aug 18, 2006
booba5185's Avatar
well cathodes are easy, just run them to your trunk light so your not lighting a closed trunk
Old Aug 18, 2006
mishqua's Avatar
True but when I drop the rear seats I like the light. That and there pretty cheap to replace.
h4ldol
Apr 24, 2017 08:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
Deebo12
Air Conditioning
Sep 26, 2015 11:08 PM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
