Double din?
Old Aug 17, 2006
slowcivic2die4's Avatar
slowcivic2die4 is an unknown quantity at this point
Double din?
I just got the Pioneer AVICZ1 and its a double din unit. Does the 05 come with a stock double din housing. If so Ill just pick one up. Thanks ahead of time to anyone with info.
Old Aug 17, 2006
05reverb's Avatar
05reverb is an unknown quantity at this point
you got the Z1??? you son of a b***h, i love that HU, give it to me , but seriously, nice HU. as for the double din, you can get the stock honda dash for a civic SE (US) or civic reverb (CANADA), it is double din and would look best, unless its very expensive, then you could get a double din kit from crutchfield or something.
Old Aug 17, 2006
shifoe's Avatar
shifoe is an unknown quantity at this point
The only double dins I've seen have the seperator in the middle or the pocket. I got one and had to dremel it to fit my screen.
Old Aug 17, 2006
05reverb's Avatar
you can buy the factory honda SE or Reverb dash for probably around 50$, here's mine with a double din HU. it's a perfect fit cause my stock was also double din, so all you need to do is bolt the new HU.
Old Aug 18, 2006
jameStype's Avatar
jameStype is an unknown quantity at this point
Here's the doubledin kit metra makes that is sold at the circuit city website -
http://www.7thgencivic.com/forums/sh...d.php?t=274441
it will house 2 HUs or one double din screen.
Old Aug 18, 2006
02SILVEREX's Avatar
02SILVEREX has a little shameless behaviour in the past
And this is what it will look like.... Just use the Metra kit, you'll need to remove the center "seperator", and also trim the top a little. Because of the shape of our dash, the radio will tilt back, causing the face to rub when opening and closing.
Old Aug 18, 2006
MegaHurtz's Avatar
Here you go
http://www.autotoys.com/x/cust/produ...productid=2523
Old Aug 19, 2006
Thanks guys just got one out of an 05 se for 50 bucks. I hope to hive it in soon!! Thanks for the help!!
UltraHDGames
Jun 8, 2016 05:16 PM
solarpunk70
Apr 12, 2016 11:43 AM
Cam Diaz
Sep 28, 2015 08:34 PM
carid
Sep 28, 2015 10:13 AM
zeshan7616
Sep 15, 2015 12:24 PM
