does dynamat license plate holder work?
Old Mar 10, 2002
neoretromax's Avatar
neoretromax is an unknown quantity at this point
does the dynamat license plate holder stop lp from rattling? Please only people who have this product.
Old Mar 10, 2002
Voiceofid's Avatar
End Bringer
does kinda, should put some doible side taping on it too!
Old Mar 10, 2002
mohawkboom's Avatar
Nope.. Doesn't work well because we have 2 bolt mounts..not 4.. U just used some 1/4 3m adhesive foam under the plate.. and covered the back of the plate in Brown Bread.
Cheers
Mohawk
Old Mar 10, 2002
Voiceofid's Avatar
End Bringer
<< Nope.. Doesn't work well because we have 2 bolt mounts..not 4.. U just used some 1/4 3m adhesive foam under the plate.. and covered the back of the plate in Brown Bread.
Cheers
Mohawk
it does work a bit, my plate stop rattling, but now it's my trunk's turn
Old Mar 10, 2002
so what's the best thing to stop rear plate from rattling?
Old Mar 10, 2002
mohawkboom's Avatar
3M Adhesive foam tape [IMG]i/expressions/face-icon-small-smile.gif[/IMG] or buy th Dynamat Licence plate kit. Use the Sheet of Dynamat extreme and the 3 foam strips..just don't use the license plate holder.
Cheers
Mohawk
Old Mar 10, 2002
well i got the foam tape on right now, but it still rattles a lot so i guess i'll just get rid of the frame and stick the plate down as good as i can with some matting behind it.
Old Mar 10, 2002
mohawkboom's Avatar
with 2 bolt setups the frame actually adds rattles.. no frame.. just the Dynamat extreme and foram should do the trick
Old Mar 12, 2002
tsunamisplash's Avatar
tsunamisplash is an unknown quantity at this point
i just used the things you put on the bottom of chair legs and table legs. no rattling at all. if you put them in all the right spots.. it dampens it quite well for very little money.
Old Mar 12, 2002
AzNMan's Avatar
AzNMan is an unknown quantity at this point
it doesnt work jus stick something like pieces of mouse pad on there and ur good to go
Old Mar 13, 2002
CIVIC9782's Avatar
CIVIC9782 is an unknown quantity at this point
nope. that thing is a rip off. just go and buy some regular dynamat and put that behind your normal license plate . that will work.
civic9782
Hrddrvs
Apr 11, 2015 11:22 PM
technosilver
Nov 16, 2001 07:00 PM
wawacito
Nov 5, 2001 03:32 PM
