Electrical problems, please help!
Old Aug 4, 2006
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
Posted in the problems section a few days ago about my ABS light coming on, then having my gauges go dead which would eventually lead to my car losing all power going dead. Had the alternator tested and the test came back that it wasn't putting out enough power, so I replaced it with a brand new one from Napa.
Put in the new one yesterday, and it drove around perfect last night with all my accessories on. I just went out to the store today, and as soon as I had my A/C on, the same problem came back. I parked my car, went and bought some food, came back, and my car wouldn't start. The charge indicator eye on the battery is bright green meaning it's charged but it won't even turn over, it just clicks.
All of these problems came a few weeks after i uninstalled my nitrous kit, but I dont' know how that would have anything to do with it. Please help!~
**Update** Just got back from autozone, tested the alternator putting out 8 amps at 2k rpms, tried to do an idle test and the car would not idle at all. Just went up and down between 1000 and 1500. Mind you this is a brand new alternator. I'm completely stumped.
Old Aug 4, 2006
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
Did the Nitrous kit have any kind of electrical wires that were part of the system? (I don't know). There might be a hot wire in the car that is connected to the battery and is grounded out, causing the battery to disharge. That would be the only explaination besides something wrong within the electrical system components.
Old Aug 4, 2006
scansel912's Avatar
The problem is, is that the car is dying while I am driving. I think the gauges aren't getting the proper voltage when I am driving which is why they are acting up.
Old Aug 4, 2006
Taffy's Avatar
Hmmm...yeah that has happened to me before on an old car, died while I was driving, it was a bad alternator. Did you purchase that alternator from Napa as a refurbished one? I would check on that make sure you didn't get a bunk one.
Old Aug 4, 2006
scansel912's Avatar
Yeah, im going to go to the parking lot, take the battery out, charge it up, then go to autozone to test it.
However, I have no battery charge light coming on like I did a few days ago before I fixed the alternator. Could there be a problem with a fuse or a wire?
Old Aug 4, 2006
Taffy's Avatar
The battery wouldn't have anything to do with your car dying while your driving. It's main purpose is to start your car and run the electrical components when the car is off. I'm thinking it's a faulty alternator, even the new one...If you have a Multimeter handy, meter the output of the Alternator and make sure it's putting about 6V AC.
Old Aug 4, 2006
scansel912's Avatar
I'm gonna take it to autozone here in about an hour, I'll post up the results.
Man, what are the odds that the alternator I bought is bad too. It was a bitch to put in haha, not looking forward to doing that all over again.
Bump for update on first post.
Old Aug 4, 2006
zen_master's Avatar
what kind of aftermarket stuff u got on ur car?
might want to turn back the clock so you can diagnose the problem properly..
Old Aug 4, 2006
pon55's Avatar
A Check your ground cables, especialy the engine ground.
B Have a load test done on your battery.(could have an internal short)
c If the above are good look at all the areas you have been working in
while removeing your mods. Good luck.
Old Aug 4, 2006
zen_master's Avatar
o yea....
i second "A"
check your ground!!
Old Aug 4, 2006
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
sounds like the voltage regulator that controls your alternator
Old Aug 4, 2006
BlackKnight008's Avatar
420 Member
BlackKnight008 has a spectacular aura aboutBlackKnight008 has a spectacular aura aboutBlackKnight008 has a spectacular aura about
id check the grounnd for sure my car died today in the niddle of the street because my ground came out while driving
Old Aug 5, 2006
scansel912's Avatar
Where is the voltage regulator? My dad had suggested that, but I thought they were built into the alternator.
I checked all my engine grounds and they seemed fine. Tomorrow I'm going to check all the wires that my nitrous kit was near.
Old Aug 5, 2006
its called the ELD (electrical load detector) and is under the fusebox in the engine compartment. Theres a few threads on the board about issues with it
Old Aug 5, 2006
scansel912's Avatar
There was a lose wire going to my fuse box, tightened it, and all my problems seemed to have gone away.
Had the alternator checked at autozone, and it was putting out 30 amps instead of 8. Still low, but im sure the lady did the test wrong because she hooked up the stuff in different places then all the other people before.
CarStuff
Dec 6, 2020 12:52 PM
juror
May 26, 2015 06:35 PM
steveneddy
May 19, 2015 02:39 PM
ywgflyer
May 15, 2015 05:05 PM
Ronin
Nov 17, 2001 09:46 PM
