cap question
Old Jul 24, 2006
cannonfolder's Avatar
cannonfolder is an unknown quantity at this point
cap question
How do u guys prevent from blowing ur alt with our cheap a$$ 70 amps.I blew two already.
I have a 1.5 ferad cap in my closet that I haven't installed yet,would that help?
Old Jul 26, 2006
ashtonp's Avatar
ashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to behold
run a 4awg to the back of the car to another battery.
Old Jul 28, 2006
Wouldn't that still ask the same amount of amps from my alternator, or would I have to charge the extra battery with a charger evertime it goes low?
Old Aug 1, 2006
ashtonp's Avatar
you wouldn't have to charge the battery over time, the alternator would do that for you, it would just take longer to charge while the car is on.
Make sure the battery is deep cycle and spill proof, i doubt you want acid all over your trunk floor
Old Aug 2, 2006
The wires going from your altenator to your battery,did you change them to 4 gauge or did you keep them stock? I'm guessing that you wired your second battery in parallel from the first battery leads.
So I guess capacitors are useless in saving an altenator. I'm going to follow your advice and pick up another bat.
You seem to know your stuff on audio so I'm going to ask for your opinion about my subs. I have my 2 Infinity kappa perfects 12 vQ's in a sealed enclosure running off a alpine MRD-M501 which produces 550Wx1 rms at 2 ohms. The subs handle 400 watts rms each. DO you think it is worth it to invest in a second amp to drive my subs, and will I notice a huge difference for the money spent?
Thanks
Old Aug 2, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
A good capacitor with the correct farad will help your car out a lot!!!!
& you won’t blow any more alt's.
But a battery in the trunk is a great idea!!!
Id love to get a battery in the trunk for my system.
Old Aug 2, 2006
I'm not disagreeing with you but I heard from someone thet a cap is useless if you are trying to save your alt because, the same amount of amperage is still demanded from it to run the power.If you think otherwise can you explain how it reduces the strain on the alt?
Old Aug 2, 2006
02BLKCIVIC's Avatar
hmmm good point!^^^
I have a 2000 watt system & a cap with no problems.
But that could be true, because the cap will only hold energy to protect from "surging."
Wile you are still pulling the same amount of amps because of the system....
hmmmm well.
Some one please enlighten us...
Old Aug 3, 2006
I guess nobody can come up with a hardcore explination
Old Aug 3, 2006
02BLKCIVIC's Avatar
I post a thread now see if we can get some answers...^
hear we go http://www.7thgencivic.com/forums/sh...00#post3974000
see what that thread generates.
Old Aug 4, 2006
WhiteRabbit's Avatar
no, a cap wont save your alternator.
if youve gone through two, that means that the root cause of what blew the first one has not been corrected. thus, the second one blew.
in rare cases, the replacement part is also bad. I'm not convinced this is the case, because no alternate troubleshooting has been performed.
I can't tell you what the root cause of popping your alternators is, but it's very likely (very high confidence factor) that a capacitor will not fix what the root cause is.
Bummer of a situation in general. if it goes a third time, I would request to talk to someone who does product support for Honda of America, see if they have seen anything like your situation. its more likely they would know from experience a list of potential root causes and methods of troubleshooting.
Old Aug 4, 2006
You seem to know your electronics pretty well, what do you do for a living?
Old Aug 5, 2006
field service engineer
SimpleUser
Apr 24, 2021 02:54 AM
liagreenhalgh92
Jul 21, 2015 01:31 PM
Kyles24
Jul 16, 2015 10:14 PM
Kyles24
Jul 12, 2015 09:15 PM
Hqly2001
22
Jul 12, 2015 06:44 PM
