Lyrics out of my Sub
Old Jul 23, 2006
Saimab786's Avatar
Saimab786 is an unknown quantity at this point
I managed to get my JBL amp installed and my Sub hooked up. The problem is, no matter what I set the crossover to, I get lyrics coming out of the sub, alongwith bass. But the bass is not that hard ditting, it is probably cuz the sub has been repaired. Why are there lyrics coming out of the sub, is it time to get a new sub perhaps or is something in my setup that needs to be changed.
I have a Alpine 9847 HU, with the subwoofer on and to full volume.
The SUB is an older MTX 6000 Thunder I think
Old Jul 23, 2006
_unclejuice's Avatar
_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough
you using an internal or external crossover? as long as its on low pass nothing but bass should come out.
Old Jul 23, 2006
05reverb's Avatar
05reverb is an unknown quantity at this point
you probably have the crossover switch on your amp set to high pass instead of low pass, if that is not the case your switch or internal crossover might be fawked.
Old Jul 23, 2006
ashtonp's Avatar
ashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to behold
if your using a multi-channel amp make sure its bridged properly.
Old Jul 24, 2006
Saimab786's Avatar
I am using the JBL GTO 75.2 ii, and it looks as if it is bridged correctly. The only possiblity would be that the internal crossover might be messed, eventhough this is a brand new AMP? I guess I can just go back to Bestbuy and get them to exchange just the amp, for my piece of mind. It cant be the sub, right? This is a crossover issue?
Old Jul 24, 2006
thats what it sounds like. the sub only puts out what the amp tells it to.
Old Jul 24, 2006
phuviano's Avatar
Slowest 7thgen in the GTA
Yes sounds like a crossover issue to me. No it can't be the sub. The sub is just like any other speaker. It will produce sounds that it is given.
Did you make sure that you are using the correct set of pre outs. Did you make sure you are using the "Sub" pre outs, and not the "rear" pre outs???
