Passenger Speaker
Old Jul 2, 2006
thefever's Avatar
I need a drop
thefever is a jewel in the roughthefever is a jewel in the roughthefever is a jewel in the rough
Passenger Speaker
So, I finally decided it was time to replace my speakers. I thought my passenger side one had blown or something. I hooked up my new speakers to it and surprise, no sound. Nothing. I guess it's the wires or something, unless y'all can think of anything else. I'm thinking about just rewiring those wires, and see how that goes. Or maybe I'll just amp them. I dunno. Any suggestions would be appreciated.
Old Jul 2, 2006
Rennen's Avatar
New Mod on the Block
maybe the wiring from you headunit is loose or fvcked up.
Old Jul 2, 2006
thefever's Avatar
I need a drop
nah, it's a brand new headunit, it did the same thing with my past 2 hu's as well.
Old Jul 2, 2006
Civicman1988's Avatar
rewire it with bigger gauge wire for better sound. Thats what i am going to do when i hook my speakers up
Old Jul 2, 2006
Kevbotron's Avatar
I like my commute
How did you mount the new speaker in the door? I drilled mine in, and somehow the magnet from the speaker touching the door disabled it (no sound). So I wrapped some foam around it and it works, dunno if this is the case with you however.
Old Jul 2, 2006
ya did you use a spacer? have you rolled down the window and had it get stuck? most speaker needs 1 inch spacer to fit properly.
Old Jul 3, 2006
thefever's Avatar
I need a drop
no, everythings fine. Today I hooked it up to an amp just for giggles, and the speaker works fine. I guess it's the wires coming from the HU where I can't see. Would y'all suggest running new wires, cause I really am not sure about running my speakers off my amp. Just too much trouble.
Old Jul 3, 2006
ya just run new wires. you'll have to even with an amp since the stock ones are bad.
Old Jul 3, 2006
thefever's Avatar
I need a drop
I just finished hooking up my speakers to the amp. I found an old 4 channel amp laying around and it'll do for the time being, esp. when I get my new infinity tweeters Thanks for all y'alls help. Oh yeah, I did use the spacer, I also put some dynamat in. I just drilled new holes for the speakers. It sounds really good. I'm running a Rockford Fosgate P2 10 and then the Infinity 6021(I think) they're the reference series.
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
lowlife9
Oct 6, 2015 04:39 PM
Wariogamer
Sep 29, 2015 09:49 AM
rovafa2002
Sep 28, 2015 06:57 PM
