hooking car subs to home stereo.
Old Jun 19, 2006
Rennen's Avatar
New Mod on the Block
ever since i took out my subs from my car, they've just been sitting in my garage. i just had the idea that i could hook them up to my home stereo. i just need to know how to power them. do i need some sort of power converter? then all i would need is a hi to low converter to get a sound signal. is there anything else i would need?
Old Jun 19, 2006
Stearic's Avatar
Stearic is an unknown quantity at this point
Here is a bump for you. I have a total of 5 subs sitting in my basement that i'm not going to be putting in my car either, would be nice to have more bass for my stereo.
Old Jun 19, 2006
SLO REX's Avatar
250+ awhp Stage 2
Umm it isn't smart to hook up car speakers to home theater amps. I believe it can blow your subs. Something with the amps being different.
Old Jun 19, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
I say just buy an extra car battery...
I have a 12 hooked up to a boom box and a cd palyer.
Its all one getto peace.
Old Jun 19, 2006
depotcivic's Avatar
depotcivic has a spectacular aura aboutdepotcivic has a spectacular aura aboutdepotcivic has a spectacular aura about
^^pics? lol
Old Jun 19, 2006
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
you'll be fine hooking up car subwoofers to HT amps, a speaker is a speaker. As long as your impedences all match you'll be fine. I know my stereo receiver has an option to switch between 4 and 8 ohm outputs while my HT receiver only operates at 8 ohms
Old Jun 19, 2006
02BLKCIVIC's Avatar
Originally Posted by depotcivic
^^pics? lol
lol I'll take a pic off my phone later tonight.
Old Jun 19, 2006
half_n_half17's Avatar
half_n_half17 is an unknown quantity at this point
I recently hooked up a MB Quart Car sub to my computer's system. It's a dual 4 ohm sub so I wired it up for 8ohms and hooked it up to a spare stereo receiver I had laying around. Most home audio receivers are set up to handle 8 ohm loads, but there are some out there that can handle 4. If you don't want to go that route you can purchase sub amp plates that integrate right into your sub box and run off 110 AC.
Old Jun 19, 2006
blackBDMcivicLX's Avatar
For every sprinkle I find, I shall kill you.
blackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant future
I did it back in the day before I had my license, didn't bring very much boom unless the sterio or reciever had big wattage. Even then it wasn't too big. Never hurt them though, and they were even a really crappy brand that I bought cheap just for that reason.
Old Jun 19, 2006
shmik1's Avatar
its easy to do.. buy a plate amp from partsexpress.
I have a type S with a 200w amp.. (4ohm of course)
http://www.partsexpress.com/pe/showd...number=300-796
Old Jun 20, 2006
WhiteRabbit's Avatar
with the plate amps and an oversized box, some car subwoofers work great in the home.
its just not practical with a car amplifier.
sometimes you can get away with reciever power. id make sure you have high loads. 8-16 ohms. some recievers can handle 4 ohm loads, but most freak out a little bit.
Old Jun 20, 2006
Rennen's Avatar
i still have my car amp. i just need to know how to power the car amp with an plug. kinda like how they have it setup at best buy.
Old Jun 20, 2006
2k2_civic_ex_4d's Avatar
2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold
I totally agree. I tried it the other way around once, I put my home theater sub in the trunk, that **** hit so fvckin hard you wouldn't believe it.
Old Jun 20, 2006
the right way to do it would include buying a DC power supply and hooking it up that way. better bring alot of cash with you
the cheaper way to do it would be a car battery and a battery charger
Old Jun 20, 2006
Devani's Avatar
Devani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond repute
I have a 12V DC power supply with 20A. It wasn't that expensive at the time. It sounds nice and this is preferred method to use car amp and sub..
Old Jun 20, 2006
diskreet's Avatar
Just watch the amp cause many outputs on a home audio amp are 8 ohm and many subs are 4 or 2 ohm.
You will get more power to the sub, by hooking it up to the amp in your house, but you are really straining the amp.
Old Jun 20, 2006
Dominatorp1's Avatar
Dominatorp1 is an unknown quantity at this point
I had two alpines subs and a rockford amp connected to my PC.. What i did was connect my subs like normal to my amp, aux to rca from pc to amp, and had the amp running off a boat battery (they have better deep cycle), and a boat batter charger.. Work amazing and sounds great..
Old Jun 20, 2006
20 amps wont get you very far
Old Jun 20, 2006
struggling at 600 rms class a/b. Ill bet itll go up to around a killowatt class D, playing music.
Old Jun 21, 2006
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
Just go do a run out at a local car audio shop with a converter. JK JK JK don't do that. We would stay late to play video games with 3 sets of boston z6, 4 t2's and 8 Type R's hooked up to the PS2. Man that **** was loud.
Old Jun 22, 2006
Rennen's Avatar
ok. this is turing out to be more work than its worth. is there an easy way to hook up the amp to a plug? damn... i sound like a n00b... this sucks... i really dont want to spend that much... because... honestly... i really dont care that much about it that much. lol.
Old Jun 22, 2006
diskreet's Avatar
If your reciever/amp is rated for, say, 50 watts RMS @ 8 ohms then if you hook a 4 ohm sub up you will be giving it anywhere from 75-100+ watts RMS depending on how its built. No matter what, though, if it's made for 8 ohms then a 4 ohm load is bad for the electronics.
Otherwise find out what impedence the outputs are for and wire the sub up that way.
Old Jun 22, 2006
ok. this is turing out to be more work than its worth. ... i really dont care that much about it that much. lol.
Youve figured out the secret. Its funny, because we just tell people this at the beginning in these threads (and there are a TON of these threads out there!) but noone believes us.
you actualy "get it."
Old Jun 23, 2006
ashtonp's Avatar
ashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to behold
its not that hard man. Hook up your subs to your car amp like you normally would, then run a + and - to a car battery charger and run it at 14.4 volts. Theres a $50 solution for you. We did this with my buddys two JL 12w3v2's with a Jensen amp for a house party we had, works fine, try it out.
Old Jun 23, 2006
shmik1's Avatar
I agree with this too, BUT... just buy a plate amp and forget about using ur car amp. I've been running my Type S off a 200w amp, for about 2 years since I already had the sub the $120ish i spent on the plate amp was much cheaper than $400 for a home theater sub, and it sounds just fine. If I had the $ of course I'd upgrade to 2 type Rs, and get a 1000watt amp.. but the typeS with 200watts is just fine for now..
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
tylerginevan
Apr 27, 2015 12:29 PM
cheekyvirgin
Bluetooth
Apr 27, 2015 05:31 AM
McD
Apr 16, 2015 10:46 AM
ej8
Apr 13, 2015 06:36 PM
