allways on hu
Old Jun 18, 2006
Imtheconvict's Avatar
Imtheconvict has a little shameless behaviour in the past
allways on hu
say i wanted 2 make my headunit be able to turn on when no key but still turn off when the car is turned off could i run a 4 way switch dpdt with the top connected to the turn on middle 2 the hu and the third taped into the constant on the harness the wireing might not be right but has anyone done this
Old Jun 18, 2006
05reverb's Avatar
05reverb is an unknown quantity at this point
get a spdt (3way), connect the common terminal of the switch to the red Headunit wire (acc.), then connect one of the other terminals to the ignition wire from the car, and the other terminal to constant 12V +. when the switch will be one way, it will run normally with the key, but when you flip it the other way, it will be on no matter if key is in or not.
Old Jun 19, 2006
do i have to cut the wires on the harness or can i just tap into them with like a blue line tapper where it strips the wire and the 2 connect without cutting id i have to cut them what ends do i need 2 attach 2 the switch im thinkin about it and tapin would pob work cuz you still get the power right so its basically and red and yellow for with the key and red and 12v for allways on what gauge wire is usually used 2
forget it i did it allready i just tap the yellow and red wires and but them on a switch switch on radio on switch on turns on like normal
Last edited by Imtheconvict; Jun 19, 2006 at 12:26 PM. Reason: Automerged Doublepost
Old Jun 19, 2006
05reverb's Avatar
ya it works like that too, but it's not the right way to do it cause now your feeding your red wire with power when car is off and you turn on the switch, so maybe it's sending power to other places, that are not supposed to have power when off, check your power outlet (lighter), that maybe getting power when switch is on
Old Jun 21, 2006
i just went and checked the the lighter is getting power and thats pretty sick cuz that was gunna be the next thing i did the power outlet allways on so thats good enough sick
soufigured
15
Aug 18, 2015 08:22 PM
Rawr51x
Oct 20, 2008 10:05 PM
atl01
Georgia
46
Jul 12, 2005 07:50 PM
PICHY
Apr 18, 2005 05:33 PM
