Help needed choosing speakers please
Old Jun 9, 2006
Earthworm's Avatar
Earthworm is an unknown quantity at this point
Hi, I've just bought and installed a new HU (JVC KD-SHX751) which rated at 51 Watts. Now I want to replace my car's speakers to do it justice. I'm a big fan of Ebay and have noticed some Infinity Kappa 652.7i's and 62.7i's on there. Both priced at £64.99 per pair. I have been told by the seller that the 652.7i's would be compatible in both the front and back of the car as they are 6.5 inchers. Can anyone confirm this because using the "vehicle fit guide" service on the Infinity website, only the 62.7i's come up as being compatible with a Honda Sport 2003. Confusing! Also, can anyone comment if eithof these speakers would be a good choice? I've noticed that the very best online price is around £90 so this seems like a good buy. And if I do get them, will I be needing spacers? I'll shut up now.
Cheers,
Dave
Old Jun 9, 2006
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
They will fit that's for sure. What are the specs on those speakers?
Old Jun 9, 2006
Earthworm's Avatar
62.7i:
Power Handling, RMS: 75 Watts
Power Handling, Peak: 225 Watts
Sensitivity: 94dB
Frequency Response: 45Hz - 25kHz
Mounting Depth: 2-3/16"
Impedance: 2 Ohms
652.7i:
Sensitivity: 94dB
Impedance: 2 Ohms
Posted direct from the Infinity website. Exactly the same specs. The Ebay seller emailed to say that the 652.7i have a 6.5 fitment and the 62.7i have a 6.0 fitment. Also the 652.7i's seem to have a lot more fixing screw holes around the perimeter.
Anyway, he said the 652.i's are compatible but the Infinity website said it's the 62.7i's that are compatible. Which would you suggest I buy???
I guess that if both sizea are ok I should go for the larger 652.7i's as the extra screw holes might make the installation more straight forward.
One last thing, I thought I heard someone mention here that they fitted some 6x9's in the rear. On Ebay there are some KAPPA 693.7i 6x9's at £77.50. Would these go in the rear or would I have to stick to the 6 or 6.5 inchers mentioned above. What do you think?
Old Jun 9, 2006
diskreet's Avatar
I cant comment on the size, as I dont have time to read everything you posted, but as for infinity:
I have yet to be anything but surprised with how good Infinity products are for the price. You get $200 infinity speakers, and you get much more than most other $200 speakers.
Old Jun 9, 2006
kappa are great speakers, but am amp is pretty much required for decent sound. the deck barely puts out 15wrms per channel if you're lucky. the kappa can take 75wrms so you need an amp that will give at least 1/2 or more of that per channel.
Old Jun 9, 2006
Kyle23's Avatar
Exactly. U should really get an amp for those speakers if you want them to sound as good as a $225 speaker should.
You can fit 6x9's in the back but sometime you have to trim the metal. I have 6x9 Diamond Audio's in my 04 EX coupe
Old Jun 9, 2006
Earthworm's Avatar
OK. Thanks for the suggestions guys. I presume that the 3 way Infinity 693.7i 6x9's would provide better sound than the 2 way speakers I was considering so I will buy a pair for the rear and go for the 652.7i in the front as I guess 6x9's will not also fit at the front (am I right?). As for the amp, what would you suggest? Are Infinity amps as good as their speakers? By the way, the specs for for the 6x9's are:
110 Watts
330 Watts
Sensitivity:
95dB
Frequency Response:
35Hz - 25kHz
Mounting Depth:
3-3/16"
Impedance:
2 Ohms
Many thanks again,
Daves
Old Jun 9, 2006
i would look at alpines new amps. and you prolly want a 4 channel amp to run all the speakers off of. and you want the ohm load to match, i think its 4 ohm. 2way and 3way doesnt really matter. for coupe, rear is 6x9, front 6.5 i believe.
Old Jun 9, 2006
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
110 Watts
330 Watts
Sensitivity:
95dB
Frequency Response:
35Hz - 25kHz
Mounting Depth:
3-3/16"
Impedance:
2 Ohms
Many thanks again,
Daves
Your going to need an amp for these kappas, they run at 2 ohms, too low of an impedance for most headunits
Old Jun 12, 2006
Earthworm's Avatar
Thanks for the advice. I have since been advised that the civic will not take 6x9's in the rear without some serious cutting so I'll get the 652.7i's (75W RMS) for front and rear. As for powering them, in the FAQ section of Bassjunkies.com it seems to suggest that amps that are presented with a 2 ohm speaker load will generally double the RMS to compensate. Is this right? I don't really want to buy a separate amp just yet if the JVC headunit (22W RMS into 4 ohms) will suffice for the time being. Can anyone comment on this please?
Old Jun 14, 2006
generally an amplifier will increase its ouput as the impedence drops. If your going to be running kappa speakers you must run them off a headunit since they operate at 2 ohms. If you hook them up to your jvc it might work for a few moments before blowing fuses or smoking the output stage of your headunit.
Old Jun 14, 2006
i think you meant amp instead of headunit
Old Jun 15, 2006
Earthworm's Avatar
Thanks for the advice. I've decided to go for an Alpine MRV-F340 or the more recent MRV-F345. I believe this will match the speakers power ratings very well.
Old Jun 15, 2006
WLakers
May 4, 2015 06:23 PM
cheekyvirgin
Bluetooth
Apr 27, 2015 05:31 AM
Myredjonda
Apr 14, 2015 07:00 PM
SilverCivicCoupe68
Nov 30, 2001 02:34 PM
supercivic01
South
Nov 30, 2001 11:27 AM
