Fuse for push-button ignition
Old May 29, 2006
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
I'm installing a push button ignition along with switches for the accessories. For the power I have a fused distribution block from the battery, and my question is, what kind of amperage levels am I looking at, so I can get an appropriate fuse? There's got to be a lot of power (this includes the starter button also), but I don't want to let any more power past the fuse than I have to, so could anyone give me a ballpark estimate on what fuse I should get? Thanks.
Old May 29, 2006
WhiteRabbit's Avatar
First thing I would do is make sure my fuse holder took many standard sized fuses, so I could pick from a range, just in case I got the wrong size fuses.
After that, I would probably think more in terms of the current capacity of the wire, rather than the ignition. Ultimately, the fuse is there to protect the car from a short, so all I really want that fuse ot do is burn before the wire does in case of a short.
alternately, I could buy a series of small fuses, starting at 25 amps, say, and put one in and try to start the car. if the start fails, id put in a 30 amp. If the car successfully started, id probably put in a 35 or 40 and call it a day.
Old May 29, 2006
jwalker87's Avatar
Bodacious Member
fuses are pretty cheap, so i guess experimenting until it works then bumping it up 5 amps would be a good way to go.
Rlss
24
Feb 26, 2016 09:42 PM
Uan
Aug 23, 2015 03:03 AM
mr_cb7
Aug 11, 2015 09:20 PM
liamfry91
Aug 9, 2015 07:54 AM
Civic65
Jul 19, 2015 10:13 AM
