Does a 8 inch screen fit in the dash?
Old May 24, 2006
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
I want to put a flush mount screen in my car with as little fabrication as possible. And I definitely don't want to cut my dash. Can we fit a 8 inch or do I have to stick with a 7 inch?
bgump
Old May 24, 2006
PopcornPlaya's Avatar
Electric Boogaloo...
Derek managed to get a 12 inch in his dash a while back. He had to move the A/C controls and stuff, but it fit. Anything will fit, with enough determination to do it. As far as fitting it in the stock location of the radio, 7 inch is about the max opening, as it's a double din opening. You might can squeeze and 8 incher in there, but it might not be flush. If you're going to do it, I recommend recessing it as the dash angle will create glare. Search for J187's DIY thread he did a while back about it. I don't know if Mega ever put it in the sticky.
Old May 24, 2006
DeX's Avatar
DeX
Canadian, Eh!
I searched for posts in his name and found one but the DIY in it has no pictures. Is there another?
I was thinking about getting the Xenarc 700TSV but don't know if I should get the 7 inch or 8 inch.
Old May 24, 2006
http://www.7thgencivic.com/forums/se...earchid=891895
Second link
It's also in the sticky (mega finally put it there evidently)
http://www.7thgencivic.com/forums/sh...d.php?t=210136
Fabricating a touch screen into the dash is the thread title.
Old May 24, 2006
cleancivic 05's Avatar
cleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trusted
stick with 7
cdt12271
Apr 23, 2015 11:36 AM
XtremelySpoiled
Dec 13, 2001 09:38 PM
BiGbRoWn
Bolt-on Engine Performance
Nov 21, 2001 06:17 PM
