Need some help with my box
Old May 20, 2006
XNeewbie's Avatar
XNeewbie is an unknown quantity at this point
Hey guys I’m making a box for my 2-10" and I need some dimensions for my civic...
My idea is to have two vented holes on the sides...
It's a civic 05 lx...
Would appreciate the help thanks.
Old May 21, 2006
WhiteRabbit's Avatar
nab a tape measure and go to work!
I think youll find youll be more limited by what can get through the hatch than by what actualy fits in the car!
Old May 21, 2006
XNeewbie's Avatar
Don't need the box to fit perfectly...
Just want it to fit and look good
Old May 21, 2006
iLLuMiNaTi's Avatar
iLLuMiNaTi is an unknown quantity at this point
unless you plan on competing, i don't really recommend going ported. but if you're set on that idea and you want them to sound good (not just loud), find out what the manufacturer's recommended dimensions are, or calculate them based on their specs. vented boxes can be very tricky.
Old May 21, 2006
XNeewbie's Avatar
Thanx guys...
Is anyone out there with a 2-10" sub in their civic 04-05??
I would appreciate some ideas or so.
Old May 21, 2006
Sephiroth619's Avatar
Sephiroth619 is an unknown quantity at this point
What subs are you using?
Old May 21, 2006
Originally Posted by XNeewbie
Thanx guys...
Im sorry, but I have WAY WAY too many ideas for you.
what do you want?
subwoofers off the rear deck, subwoofers under the floor, subwoofers in a fancy box, open trunk, space taken up, whether or not you care about the trunk/cabin boundary, how good at fabrication you are, how much effort you are willing to put into the box, what the time and dollar budget you have, what performance you are looking for. the list goes ON and ON.
give me some constraints, and ill give you a couple sweet sweet designs to choose from.
WAY too many based on the criteria you have now!
Old May 21, 2006
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
i have two in the trunk of mine in a box i built meself...not bad for my first attempt IMO...gimme your email and i'll send ya a pic
Old May 21, 2006
ramcosca's Avatar
Words on a User Title
I think we also need to know if it's a coupe or sedan. I have an understanding that the trunks are different for sedans and coupes. But I only think I'm right.
Old May 21, 2006
absolutely right. its easier to gut out the rear deck of a sedan to run some IB subwoofers than it is in a coupe.
or as an alternative, its easier to fit in subwoofers in existing holes in a sedan rather than the coupe.
Old May 21, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Just follow my thread and you can make it ported and for 2 tens. Im only doing one.
Old May 21, 2006
XNeewbie's Avatar
Sry bout the info guys but heres the info:
It's a 4dr sedan 05' and I'm trying to make a box for 2-10" Rockford Fosgate Punch Z's 400 watts max.
My e-mail is XNeewbie@hotmail.com
Appreciate the help guys.
Old May 22, 2006
cleancivic 05's Avatar
cleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trusted
give more info on what u want
Old May 22, 2006
XNeewbie's Avatar
Just need some dimensions of the boxes ppl got on their civics and if possible some pics.
Old May 23, 2006
XNeewbie's Avatar
Anybody??
Old May 23, 2006
get this program Bassbox 6 pro and use it.. You can build any kind of box you want for you speeker in a given space. Or get a piencle peice of paper, get the space that is required for the 2 subs you have,*ported or sealed* and design a box that will fit in your car. Or go on ebay and buy a cheepy 10" or 12" box and put it in your tunk and be happy. Thats what a majority of the people on here do anyways. Quit being lazy and do the damb math son.
Old May 23, 2006
just about any standard dimension will fit. For your given boxrequirements (you can get those from the whitepaper included with your subwoofers), as long as you dimension the box not to be SUPER wide, or SUPER tall, or SUPER deep, its gonna fit in the car, and itll fit into the car.
does that make sense?
Old May 23, 2006
check out my page and there's a crappy pic of the box i built...2 type E 10's...sounds pretty good too...not too bass heavy (they're 10's damn....) and just loud enough to annoy the neighbors
http://www.cardomain.com/ride/1717164
Old May 23, 2006
XNeewbie's Avatar
What size is that box??
Old May 24, 2006
Rec. Sealed Enclosure 0.65 cu. ft.
18.4 liters Rec. Vented Enclosure 1.25 cu. ft.
35.4 liters Tuning Frequency (vented) 40 Hz
Go build it have fun. now this thread.
Old May 24, 2006
XNeewbie's Avatar
Thanx
h4ldol
Apr 24, 2017 08:16 PM
Raiool
Oct 1, 2015 10:42 AM
Hutch1051
Sep 29, 2015 09:20 AM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
h4ldol
Sep 17, 2015 01:25 PM
