Anti-Thief Question
Old May 23, 2006
K.Low's Avatar
K.Low is an unknown quantity at this point
Anti-Thief Question
My GF and I just went to get my 03 civic from the dealership and the radio was on the anti-thief device( i didnt know that it needed a code to make it work)...so she played with the numbers the whole way home and now it shows ErrE when i start the radio.
What should i do now ??? Im desperate without a radio.
Thanks alot guys.
Old May 23, 2006
RHCP0801's Avatar
get the code from the dealer and it will work
Old May 23, 2006
K.Low's Avatar
So the radio will work if i get the code from the dealer ? I dont need to get a new radio bc of what happened?
Thanks
Old May 23, 2006
RHCP0801's Avatar
na just get the code and it should work fine, it probably says error because you entered the wrong code too many times
Old May 23, 2006
K.Low's Avatar
Thanks alot man i was getting a little worried.
Old May 23, 2006
RHCP0801's Avatar
no problem, jut hit that smiley face in the bottom left hand corner of this post for a rep point
Old May 23, 2006
K.Low's Avatar
Done
Old May 23, 2006
RHCP0801's Avatar
thanks man
Old May 23, 2006
Diablo's Avatar
Diablo is an unknown quantity at this point
open the glove box and Check if there is a sticker on the left side, if there is one thats the code for the radio. mine came with one.
Old May 23, 2006
K.Low's Avatar
I looked everywhere and theres not a 5 digit code on the whole car...
BTW thanks for the suggestion.
Old May 23, 2006
PopcornPlaya's Avatar
Electric Boogaloo...
The radio code should be somewhere on the vin sticker either under the hood or in the door jam. Regardless, your unit has possibly locked itself out. It you start the car and it no longer says code, and instead just says err, that means the unit is locked and you have no more attempts at entering codes. If it's still asking you for a code, then you've got more attempts. I think, if I remember correctly, Honda allows you 5 attempts at inputing the code before it locks the unit. Might be wrong, but I believe that that is their security feature.
Old May 23, 2006
Diablo's Avatar
then if thats the case disconnect the battery fore about 1/2 hr the err should go away but you still will need to get the code.
Old May 24, 2006
K.Low's Avatar
In the owners manuel it says to leave the radio opened for an 1hr and then the Err should go away.
We'll see.
I called my dealer...gave me the code...radio works now .
Thanks for your help guys.
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
junkyardguy
Sep 2, 2015 06:07 PM
