Amp Smell....
Old Mar 26, 2006
jay47's Avatar
jay47 is an unknown quantity at this point
Arrow Amp Smell....
What's up guys, I was bumping in my civic with my 2 10" Kicker L5s and RF 551S amp pretty loud when I started to smell a burning smell. I immediately turned the stereo off for about 2 minutes and then turned it on really low for about a minute, to see if it would work again. To my dismay, I couldn't hear the subs. I am fairly certain that it wasn't the subs because they can handle just about anything this amp throws at them, and its very unlikely that the amp blew both at the same time, but I am concerned about the amp. I had it on for about 10 seconds on a high setting, bumping pretty loud, when this happened. I have had the setup for about 9 months and everything has worked fine but now it won't turn on. Does neone know what is wrong with the amp? Oh, and if it is most likely "fried," could someone explain what that means as far as the internal components of the amp.
Old Mar 26, 2006
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
check the amp fuse first.....
Old Mar 27, 2006
luvvegas777's Avatar
banned from avatar useage
luvvegas777 is an unknown quantity at this point
get a multimeter and meter your subs first. or if you don't know how borrow a friends box and connect to your amp and see if it plays. usually you will blow your subs before you fry an amp.
Old Mar 27, 2006
jay47's Avatar
I'll check the amp fuse, didn't think bout that and when I use the "multimeter" (isn't that also called a voltmeter?) do I just check for the ability of the subs to transmit a current? thanks
Old Mar 27, 2006
set the meter to read resistance. depending on the meter, look for a symbol that looks like a horse shoe or omega, set to read up to 20 ohms, then put read probe on + speaker terminal and black probe on - terminal. should read close to what your subs are rated at. touch the two probes together first, the meter should beep(if it has that feature) that way you know you have it set right.
Old Mar 27, 2006
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
an amp can easily blow two subs at one time...i've seen many amps blow up then output a nasty DC voltage offset afterwards...
Old Mar 31, 2006
cwo715's Avatar
Falken Master
cwo715 is just really nicecwo715 is just really nicecwo715 is just really nicecwo715 is just really nice
ive had that haha, youd be cruisin along, kickin the subs and then it stops.. you over heated the amp, your head unit still plays but no sound.. problem here.. the amp is probably behind your seat, in the trunk, the hot air from the amp heats the trunk and when your hittin the subs harder the amp works harder and creates more heat.. suddenly all the air in the trunk is warmer than in the cabin, what i did was lowered the 40 (of the 60/40) rear seat and drove around with my passenger window open to let air in there.
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
