wire colors on radio pleaase help
Old Feb 28, 2006
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
Exclamation wire colors on radio pleaase help
i have a 2002 civic lx and cant fidn radio wire colors there are 14 but my reciever harness has 12 can someone helpme find or tell me what each color means
Old Feb 28, 2006
ajhdragon's Avatar
7thgens official a$$hole
red power, yellow constant, black gorund, orange illumination(don't worry about that), white's front left, grey's front right, green's rear left, purple's rear right. blue remote, blue/white power antenna(none on ours)
Old Feb 28, 2006
jerseydetailer's Avatar
jerseydetailer has a little shameless behaviour in the past
still at it nah man j/k..i give you props for asking these questions..a lil off topc but how do you rep ppl/and whats the benefit..cuz i wanna rep you for wrenching on your own car...oh and if you havent already..any time you work on car's electrical, disconnect the negative battery terminal...but ***not***the positive only evvvver.........and if when you hook up everything and something electrical isnt working check your fuses
Old Feb 28, 2006
****late add on***** and there should be to blue ones....one with a white stripe one without....one is meant for a power antenna which we dont have the other is one is called a source which you use to connect to your amp so your amp knows when to turn on and off...can remember which...but the instructions that came with the harness will tell...if you plan on adding an amp later you can take the same guage wire and make the amp turn on wire (source) longer now...so later you dont have to pull you head unit
Old Feb 28, 2006
the thing is i cant find these colors i have different colors like white with red green with yewllow stripe red with black dark green light green blue with white stripe yellowblue with yellow stripe ....im in my car with my laptop again looking at these wires some of them dont match up with what ur idagram shows
Old Feb 28, 2006
ajhdragon's Avatar
don't hardwire your wires. go get a harness adapter for your car. its like $10 and best buy or circuit city and no headaches.
Old Feb 28, 2006
oh and pink
Old Feb 28, 2006
i already cut the wires and preped them for soldering
Old Feb 28, 2006
ajhdragon's Avatar
for future refrence. 1) don't hard wire radios. 2) if you must use t-taps. but your have to look in a hynes manual or something or maybe get the diagram from honda.
Old Feb 28, 2006
ok so i didnt understand..yeah.cutting your stock harness bad idea but ok...let me get my factory manual and see if there is a wiring diagram there i applaud you for doing this on your own...but next time post a thread on what you need and someone will give you all the info give me like 5 minutes...i will see what i got..
Old Feb 28, 2006
O_O i got like 14 wires sticking out and my car looks like its been robbed and naked
Old Feb 28, 2006
behold the power of the factory service manual ...bow all of you
Old Feb 28, 2006
i did l the connections now im left with red ...redblack and yellow green all the radio connections are in what do i do with the remaiing ....i knidna need them O_O
Old Feb 28, 2006
ok red = dash lights brightness connector
red/black = lights on signal
yellow/green=passenger door speaker (+)
Old Feb 28, 2006
i know but what do i connecgt them to? and also i connected everything and now it stil wont turn on
Old Feb 28, 2006
which wires have you connected on the radio harness?and which do you have left
Old Feb 28, 2006
i connected the radio harness to the car wires i didnt solder but just twisted them together to see if they work and they fruckin dont ...i have left just hanging around yellow green red black and red
Old Feb 28, 2006
ok try the red from car to orange from radio
and red/black from car to red from radio
Old Feb 28, 2006
and the yellow/green from car is passenger front (+) so it should be connected to grey wire(no stripe)
Old Feb 28, 2006
i dont have orange i put redblack to yellow grn and radios red
Old Feb 28, 2006
not sure what you meant...
Old Feb 28, 2006
your radio doesnt have orange..it might not..please list which wires you have left and tell me if they are from the car or radio
Old Feb 28, 2006
i put red (from the radio harness ) to yellow/grn stripe from car along with red black from car...an i dont have orange
Old Feb 28, 2006
now i dont have dash light on my speedometer and for some reason my light signal wont work
Old Feb 28, 2006
my wires are listed here http://www.dualav.com/i/product/manu...%202-16-05.pdf
Old Feb 28, 2006
redoing list*
Old Feb 28, 2006
you blew a fuse when you connect the yellow/green wire it seems..not sure what the antenna module does..its only on the 2door which i dont have?
Old Feb 28, 2006
once you get the wires connected properly, then go under you hood and open you fuse box cover..you probaly (i'm 99% sure) blew the #2 fuse....its listed as fuse number 2 and controls the audio unit, dash lights, front parking lights, front side marker lights, heater control panel, license plate lights, rear side marker lights, tailights and its a 15amp fuse
Old Feb 28, 2006
ajhdragon's Avatar
my suggestions are to check and make sur eyou have no blown fuses and then connect your plug back and get the harness adapter.
Old Feb 28, 2006
ajhdragon's Avatar
pretty sure that fuse #9 the small light fuse.
