Where to go about buying a Grounding Kit?
Old Feb 24, 2006
Aaron Bereznak's Avatar
Aaron Bereznak is an unknown quantity at this point
Anyone know where I would go about buying a Grounding Kit for my 7th gen, 2001 Honda Civic LX Sedan, automatic tranny? I saw it in the DIY section, and it seems like a good idea to do.
Old Feb 24, 2006
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
I know that you were reading one of Gearboxes threads earier and he might b making his own. Send him a pm or Google it
http://gearbox.shmikx.net/
Old Feb 24, 2006
http://www.7thgencivic.com/forums/sh...d.php?t=155307
This kit only goes to one Valve Cover, compared to GearBox's going to each Valve Cover, is there a reason for this? Thanks I'll spend him a PM sometime
Old Feb 24, 2006
gaugeof12's Avatar
gaugeof12 has a spectacular aura aboutgaugeof12 has a spectacular aura about
I believe that gearbox designed his based on a plate that goes to each coil. His version uses the same principle as the Weapon R. Connect coil packs together and ground to chassis. However if you just want the 1 wire I would bet that you could PM gearbox & he might set you up.
Old Feb 24, 2006
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
lol as soon as i saw this post i thought of gearbox his siggy is "BUY MY GROUNDING KITS!"
Old Feb 24, 2006
buy mine! the coil grounds are mostly for show, altho based on an actual product. i doubt they do much. the main kit is actually functional tho That link you posted is wrong. you only need one chassis ground.
Old Feb 24, 2006
so GearBox, I would want to buy your Custom HyperCoil Grounding System?
Old Feb 25, 2006
no get the power force factory replacement kit. that actually replaces the stock grounds with bigger wire for less resistance. And it does make a difference even if you don't notice anything. makes all the electrical components work better.
Old Feb 25, 2006
should I get both? I'm not ordering now, but just wondering
Old Feb 25, 2006
ya it wouldn't hurt. but the main kit does the most good for the car.
Old Feb 25, 2006
thanks for the advice man, how long will you be carrying these kits?
Old Feb 25, 2006
at least 3 more weeks.
Old Feb 25, 2006
phuviano's Avatar
Slowest 7thgen in the GTA
Just make your own ground wire kit. All you need is wires, and connectors. I used 4 gauge on mine.
Old Feb 25, 2006
dre2600's Avatar
exactly.
Old Feb 25, 2006
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
Originally Posted by dre2600
exactly.
x2.
some 4ga or higher grade power wire and ring terminals is all you need. no need for fancy kits
Old Feb 25, 2006
It sounds easy, but at the same time confusing, I rather just pay to make sure it's done right
Old Feb 25, 2006
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
yeah to expensive make ur own
Old Feb 25, 2006
Talking
there goes gearboxes buisness
Old Feb 25, 2006
haha well thats cool if you want to make your own. Just make sure you get gold plate ring terminals and crimp them hard or the wires will come loose and cause problems. Here are the sizes if anyone wants to make their own. But you'll be surprised how expensive it gets just for materials when you're done.
power force (factory)
7 inch small
9 inch medium
11.5 inch (the one with battery terminal)
coil grounds
3x 7.25 inch
1x 8.25 inch
Old Feb 25, 2006
FALKEN's Avatar
Civicforums Junkie
i know someone that has kits already made up and ready to ship at a cheaper price
(available in blue, bronze, red, silver, and yellow)
Old Feb 25, 2006
Falken, got any details?
Old Feb 25, 2006
ncirom2003's Avatar
i second this, youll save a ton of money. if any of it confuses you hit me up on aim. theres no need to shell out tons of money on these things trust me. ive done tests on the grounding system in our civics and they are sufficient for the car, so you wont see much differences.
Old Feb 27, 2006
sepudo's Avatar
sepudo is an unknown quantity at this point
Lightbulb
hey bro,
I just took mine off since I'm doing some other mods but I'll sell you mine if you'd like...
its in perfect condition (since wires cant really get worn down)
and you can have it for $25 +shipping (should be only $3-4)
let me know...I used 4 gauge blue wire with red end covers and gold connectors. In addition to getting the grounding benefit it looks great too.
here's what it looks like.
Old Feb 28, 2006
performance sys's Avatar
performance sys is an unknown quantity at this point
If you are interested in doing it yourself, I have the following packages available:
DIY Ground Kits $9.99 & $14.99
If you want a different length of wire, more/less connectors, just PM or email me and we will build your own kit. Wire is 4 gauge, connectors are heavy crimp style, gold plated. I have red, black, blue, purple, and silver wire.
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
duyaknow
Nov 23, 2001 07:28 PM
