Cheap Cerwin Vega
Either two:
Cerwin Vega VEGA12D4 12" Dual Voice Coil Subwoofer
$149.95
or two:
Cerwin Vega VEGA124 12" Woofer
$109.95
And with the first, do I have to do anything different to hook up a dual voice coil sub? Do i need a 4 ch. amp to have two subs running?
Thanks!
$149.95
or two:
$109.95
Thanks!
"Do i need a 4 ch. amp to have two subs running?"
nope. you could use a 1 channel, and wire the subs in serial or parallel (sp?). or you could use a 2 channel and run them in stereo 2 channel. or bridge it and wire them the same as the 1 channel. or you could use a 4 channel bridged down to 2 channels. but you definatly don't need a 4 channel, that would be impractical.
from what I have heard about them, I would stick with the MTX8000. I have never actually heard one myself, but they seem to be pretty popular. should be better than those Vegas.
Okay well what amp will you be running them with?.. How much power.. What kind of enclosure. Ported or sealed?..
I'd take the Vega's over MTX8000's any day..
Cheers
Mohawk
Cheers
Mohawk
See Listen to the Crazy Indian when he says get 2 Cerwin Vega HED's next time Nighthawk [IMG]i/expressions/face-icon-small-smile.gif[/IMG][IMG]i/expressions/face-icon-small-smile.gif[/IMG][IMG]i/expressions/face-icon-small-smile.gif[/IMG][IMG]i/expressions/face-icon-small-smile.gif[/IMG]
I'm gonna say that they would be in sealed boxes, custom made. The amp i'm not sure about, probably a phenoix gold or RF, not sure yet though. But which of those two subs would be my safest bet, if either?
Any suggestions on a budget amp? I've seen a 600w RF for about 300, is that good?
How about two of the above mentioned CV Subs powered by this amp?
POWER ACOUSTIK SP2X1600
Product Features:
dge Lit Cool Blue Neon with Diamond Cut Plexi
Exotic Black Chrome
Plexi-View Top Panel
Full Mosfet Power Supply
PWM Circuitry
Full Selectable Crossover Hi/Full/Low
PWM Circuitry
Full Selectable Crossover HI/FULL/LOW
Variable Low Pass 40 Hz- 120Hz
Variable Hi Pass 150Hz- 1.5Khz
Bass Boost @ 40Hz. & Variable 0-18 dB
Three Way Protection Circuit
System Distress Indicator
High/Low Level inputs With Floating Ground
4 Gauge Power/Ground Connection
2 ohm Stable
4 ohm RMS 310W x 2
Will this be enough to power two of these subs?
Product Features:
Exotic Black Chrome
PWM Circuitry
PWM Circuitry
2 ohm Stable
4 ohm RMS 310W x 2
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
Dawit Melese
Oct 4, 2015 08:02 PM
pilebuck13
Sep 21, 2015 10:45 PM
