help with avic-d1 install
Hello all. I am a noob, just registerd. I was trying to install a Pioneer Avic-d1 into my 02 civic and i ran into some problems.
1: is there a double din faceplate that i could purchase? i have seen the single din but naturally i need a double din.
2: this is a general question: for some reason the map on the screen is rotated 180 degrees. let me try to explain: while i am on the right side of a highway on a service road, the image on the map shows me on the left side of the highway. BUT, all the streets are correct, its just the complete image is inverted. (hard to explain).
3: where can i locate the VSS wire in the civic?
4: Has anyone figured out how to bypass the dvd while driving issue? i know in my TL i just had to add a wire to my wire harness and ground it with the parking brake wire and everything was fine. any ideas?
THANK YOU FOR THE HELP, I APPRECIATE IT!
Where did you get this system? I heard it wasn't made anymore and the D2 is coming out...
N1 is also gone and now only the N2 is out. Did I hear BS or is this true?
Sorry I am no help. hahah
7thGen's Loudest Civic...4,000 watts and climbing...
edt: by the way, i answered the VSS question below... didn't see that when i posted this yesterday...
nope, your right. im not sure where this unit came from. actually, the car and problems all belong to my friend who im helping with the install. i got a TL and i bought mine from best buy a few months back (employee discount PLUS $300 pioneer rebate
) Joined: Oct 2002
two solutions to this problem..you can buy the OEM 04-05 civic special edition dash because those come with a double DIN stock. OR you buy a metra brand dash kit, all you have to do is remove a little seperation bar, it's not hard, just sand down the rough edges.
try resetting the unit...i have no idea on this one...
i **THINK** it's white/green tracer at the ECU behind the glovebox.
yes, but this thread would get deleted if i posted the procedure. you have the right idea. PM me if youd like.
Originally Posted by kickercivic1
Can anyone please confirm that for me?
if this helps, hit me up with some rep by clicking the little smiley below
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
