competition cheater amp??
Old Feb 19, 2002
Ben's Avatar
Ben
Ben is an unknown quantity at this point
ok does anyone have a good sugestion on the most powerful cheater amp. i don't compete much but when they come through town i want to have over 1500 watts but stay in the lower watt class. thats with 1 amp. any sugestions. so far i only have looked at matts with there high current amps. they r like 1200 watts and they are in like the 50 watt class. i know i can hit 150 if i can get enough power....
Old Feb 19, 2002
mohawkboom's Avatar
Orion 275G4 I beleive is one of them... Zapco 9.0, U-Dimension u-pro 1k1.1... Hmm that's all that comes to te top of my head..
and what's your setup that you think you can break 150 [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Cheers
Mohawk
Old Feb 20, 2002
CIVIC9782's Avatar
CIVIC9782 is an unknown quantity at this point
Why do you want to cheat anyway. You do know if you get caught you will be kicked out of the competition .
Old Feb 20, 2002
mohawkboom's Avatar
The Orion and Zapco are "cheater" amps but are competition legal for the moment. They are called cheater amps because they put out low power ex 50Wrmsx2 at 4 ohm. However they can be bridged down to 1 ohm and put out over 1000Wrms...they are current;y DB Drag legal..However there are alot of people trying to get these amps banned in the street class. I Included.
Cheers
Mohawk
Old Feb 20, 2002
Ben's Avatar
Ben
well 2 power 15's with alot of power. my lil hx2 hit 143 so i think 2 power series with some good juice might get up there. maybe [IMG]i/expressions/face-icon-small-smile.gif[/IMG] anyways whats the power rating on those amps?? and no its not cheating it just makes it fair because everyone else uses them. but if they get banned than thats fine i'll still be matched fairly. i just got stuck last time with my earthquake amp rated at 2000 on the books in the high watt class. but then my buddy had matts amps and he was in like 151 and under. so its not cheating just kinda technical.
Old Feb 20, 2002
Gordo61616's Avatar
Gordo61616 is an unknown quantity at this point
how bout an earthquake d2 shredder? is that considered a cheater amp? those put about 2000 watts. it accepts 0 gauge wiring so it can draw the amps its gonna need. rock solid amp too i must say. go to www.carsound.com and search the forum. tons of info on that amp.
just an idea
Gordo
Old Feb 20, 2002
Ben's Avatar
Ben
gordo read my last reply..... i had an earthquake and no its just a mono amp and they put u in the 2000 watt class. but i did love the amp. i put it in my friends explorer check it out cause i know u like plexi .....
Old Feb 20, 2002
Gordo61616's Avatar
i missed that part sorry
Old Feb 20, 2002
VNlilMAN's Avatar
The Standard One
uh... whats a cheater amp?
Old Feb 21, 2002
Ben's Avatar
Ben
just an amp that is a low wattage to 2 chanels like 25x2 or 50x2 but when you bridge mono its over 1000. so when you pick your watt class you can be in a low watt class cause they go by 4 ohm stereo load which would be like 50 or 100 when you really have 1000 or more. kinda shi tty but alot of guys do it.
Old Feb 21, 2002
bake's Avatar
bake is an unknown quantity at this point
150 should be pretty easy to hit.... i hit 143.2 with orion xtreme 12's and an orion 150x2 amp, with stock everything else...
Old Feb 21, 2002
mohawkboom's Avatar
Bake.. 150 is pretty much Impossible in our cars without ALOT of sound deadening work. a HUGE enclosure..a big Port.. and Alotta Power. Just going by displacement of the subs. With about 7-8 cu.ft enclosure..tuned to 41hz. with 1300Wrms still no breaking 150 on paper. Add alotta sound deadening.. 2 extra batteries and a High Output alternator and I'll see it happening.. If you get a cheater amp remember that they draw MASSIVE amounts of current....There's alotta work to go into things.
Good luck.
Cheers
Mohawk
Old Feb 21, 2002
Ben's Avatar
Ben
yeah i had an earthquake amp before and i had 2 hx2 15's and it hit a 146 with no dynamat and stock bat and alt. with all the windows and doors shut. not sure with open but prob another 2 or 3 db. my buddy has a spl meter i think by audio control that they got for there store. thing was expensive too. well see what hap when i get some money and finish this.
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
