is this possible? airride + system
Old Feb 16, 2006
kumanan's Avatar
kumanan is a jewel in the roughkumanan is a jewel in the roughkumanan is a jewel in the roughkumanan is a jewel in the rough
Is it possible to put a Air ride tank + a 6.4 Cubic foot ported box for two 12'' subs in the back of a 03 civic coupe? Whats the max box size i can put in there roughly
Old Feb 16, 2006
ajhdragon's Avatar
7thgens official a$$hole
Its gonan be super tight and pretty junked up looking but you could probably fit it. I would say go with a custom enclosure.
Old Feb 16, 2006
MegaHurtz's Avatar
^^ hahaha you know any 6.4cuft prefabs?
I don't think you would even get the BOX in there, let alone the box, amps AND air ride system. Not without extensive modification.
Why do you want such a big box?
Old Feb 16, 2006
fiatdale's Avatar
fiatdale will become famous soon enoughfiatdale will become famous soon enough
6.4 cubes is huge.. especially for that tiny *** trunk. I dont think its gonna happen
Old Feb 16, 2006
notoriouspyro's Avatar
Crack kills... But then again... So do I...
notoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the rough
I'm tryin to figure that one out too... I can't picture a box that size fitting naturally let alone with even a small 3 gallon tank. Not seeing it happening... If you can fit the box in there take a pic of your trunk and I can tell you if it'll fit.... Why do you need such a large box n-e-way???
Old Feb 16, 2006
DUDEitsMATTx's Avatar
DUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura about
you should go to a good local shop and have them make a box that will fit in there good that gives you room for the air tank and the amp or w/e.. and 6.3 cu feet is wayy to big for our trunk... hah
Old Feb 16, 2006
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
gut your trunk and glass the bottom and use that as part of your box, the rest your going to have to build in the car.
You can always mount the tank to the trunk lid. Story Time!
pulled a customers 6th gen civic to install an indash and had to go into the trunk for some reason. Pulled the trunk release lever and it wouldnt budge, pulled harder and it finally popped the latch. I just assumed it was due to old age, go back to lift the trunk lid and had to use two hands. The guy welded a piece of steel to the trunk lid between the two arms and bolted a 6 gallon tank to it. talk about dumb
Old Feb 16, 2006
kumanan's Avatar
i need 6.4 cuz my audio bahn subs says ported is 3.2 EACH sub
Old Feb 17, 2006
get a better sub. There's tons of speakers out there that will perform way better in a much smaller enclosure.
Old Feb 17, 2006
Bryan35613's Avatar
Bryan35613 is an unknown quantity at this point
I got a 2003 civic hx coupe and i put a like a 3.47 cu ft. box with 2 sony xplod 12s and it fits fine...but 6 cu ft thats huge as hell....i doubt it would fit well at all.
coumadin01
Electronics
25
Jul 25, 2019 04:19 PM
mjdiaz89
Jun 21, 2016 09:26 PM
carid
Nov 7, 2015 01:46 AM
