advice required some xperienced people
Old Feb 12, 2006
  #31
thatsmrgimp2u's Avatar
An elephant.... with stamps for hands.
thatsmrgimp2u is an unknown quantity at this point
Pretty sure thats a dual box. model is 122..... 12" subs.... and 2 of them. Those subs you are getting run at 4ohm individualy and at 2ohm when wired in parallel so you need a mono =) check out crutchfieldadvisor.com for wiring diagrams. No such thing as a 14" btw (at least i dont think) =)
Old Feb 12, 2006
  #32
LowSky's Avatar
I spend way too much time on this website
LowSky is an unknown quantity at this point
this what i recommend and its all on crutchfield
Alpine CDE-9841 headunit .. $99
Infinity Reference 1240w... 12''sub $69.99 (just get one sub)
Alpine MRP-M350 mono amp.... $139.99
Q-Logic QLH-12S100 Single 12" $69.99
EFX Amplifier Wiring Kit wiring kit... $29.99
total $408.96
install it all yourself and save some yourself some money
Old Feb 12, 2006
  #33
Zeppelin8778's Avatar
Zeppelin8778 is an unknown quantity at this point
yea dude you dont need 2 subs whatsoever. u will be sacrificing quality to shell out the extra money to get 2, its a waste. just get 1 sub. 1 sub can rock a civic as hard or harder than it needs to be. trust us. get ONE
Old Feb 12, 2006
  #34
tripledoublegs's Avatar
Euro-Spec
well, its up to you if you want one or two subs. If you have the space go ahead and get the two jl's I told you. If not, go ahead and get one, dual voice coil, so you can run it at a 2ohm load, and swap the amp. Low sky recommended you some good **** also, but I would stick to the Alpine 9847. I wouldn't go as low as 9841 as for the subs, I would say the reference infinity is comparable to the w0 jl. Also the 9841 does not have an MP3 Player, its up to you if you want that feature or not, but its nice to have for a couple bucks more.
BTW, for the box, 1.5cu f might be too much for JL W0. Go buy your box from best buy or circuit city. I know they have them for about 70 dollars, and try to get something close to 1cu f / sub.
Old Feb 12, 2006
  #35
Euro-Spec
Originally Posted by civrunainfnluva
nvm, i found the boxes...but those subs you recommended are 14 inches rite? i cant find a 14 inch box...
They are 12's. I don't think they make 14inch subs.
You can find 11s, 12s, 13s and 15's but no 14 inch.
Old Feb 12, 2006
  #36
The q-logic boxes at ccity arent bad at all, i think they are 59.99 for a single 12".
Old Feb 12, 2006
  #37
Euro-Spec
yep, I had 2 of those, but the dual chamber ones
Old Feb 12, 2006
  #38
usafcushman's Avatar
7thGen's Loudest Civic...4,000 watts and climbing...
usafcushman is on a distinguished road
true, but then again there are some of us that are particularly fond of that holyshitican'tbreatheturnthatshitdown feeling, and 1 (or even 2) subs just don't cut it
Old Feb 12, 2006
  #39
Euro-Spec
hell yeah
Old Feb 12, 2006
  #40
LudlamTheory's Avatar
i boogie for the raindrops
i bet i can get that effect with a single 10
Old Feb 13, 2006
  #41
true again... but my system is primarily set up to showcase my talents in order to attract more business, and even though it's sad, 95% of potential customers are young guys that believe "more is better"... so i'm rockin 4 12"s
Old Feb 13, 2006
  #42
So what do you guys think about the new Kicker CVX's ?? have the same power handeling as their L7's.... cant wait to hear them.
Old Feb 14, 2006
  #43
CVXs =
JKWood
Jul 28, 2015 03:45 PM
carid
Wheels and Tires
Jul 20, 2015 07:15 AM
Ariah J. Davis
