Amp related Q.
Old Feb 8, 2006
05CoupeCivic's Avatar
05CoupeCivic is an unknown quantity at this point
Amp related Q.
I have a 4 channel amp but dont have speaker wire yet, if i wire the rca's, ground and power wires now and leave it until i get my speaker wire will my amp explode or anything?
Old Feb 8, 2006
also, my wires came wth a "trigger" wire.. what is this?
Old Feb 8, 2006
dtox666's Avatar
dtox666 is an unknown quantity at this point
I would assume it's the blue wire that goes from the HU to the amp to let it know the HU is on (or off).
No problem if you hook everything up before the speaker wire, but I would turn the gains down so you're not powering your amp for no reason.
Old Feb 8, 2006
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
the "trigger" wire is officially known as a remote lead. It connects to a switched 12V source that turns the amp on and off with the ignition so that the amp doesn't continue to draw power when the vehicle is OFF.
With anything you hook up amplifier wise - make sure you have a solid ground before you connect it to the battery...minimally hook up power, ground, and remote. or conversely, hook up RCA's and speaker wire and save that for last.
Old Feb 9, 2006
urwhat's Avatar
urwhat is just really niceurwhat is just really niceurwhat is just really niceurwhat is just really niceurwhat is just really nice
just leave the fuse out, so the amp doesnt turn on.
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
sesi
Oct 1, 2015 02:03 PM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
