Nakamichi PA-304
Nakamichi PA-304
Does someone have the specs for this amp? think 30x4 would be enough, or at least better than running of my Headunit? i found one for like 90 bucks, think i should buy it?
$90 for a nak amp.. take it.. and 30Wrms x4 is still a fair bit of power. the difference between 30Wrms and 50Wrms to your ears when at full output is anout 2 decibels. And Nak a,ps areVERY clean sounding.
Go for it dude.
Cheers
Mohawk
Go for it dude.
Cheers
Mohawk
These specs are for the 504. No one seems to carry the 304 anymore. POWER AMPLIFIER SPECIFICATIONS
Continuous Power Output (4 ohms) - 50W x 4 Continuous Power Output (2 ohms) - 100W x 4
Bridged Power Output (4 ohms) - 170W x 2
Power Bandwidth (Crossovers Out) - 10Hz-30kHz, -1dB
Total Harmonic Distortion - Less than 0.01%
Signal to Noise Ratio (@Min. sensitivity) - 100dB
Dimensions (W x H x D) - 9-5/8" x 2-5/8" x 13-3/4"
$349.95
$349.95
