looking to get a new amp...need help1
Old Jan 29, 2006
BlackCiv01's Avatar
BlackCiv01 is an unknown quantity at this point
Question looking to get a new amp...need help1
sup guys...currently got 2 12's mtx thunder 8000's...good subs...and im running both them of one mtx 801D mono amp....and im looking to get more power to my subs (make'em thump harder)....and im pretty much a newb when it comes to this...so i was just wondering wat i should get...as far as specs go...cause i dont know wat specs to look for in a amp to maximize the subs...
here is the AMP
http://shopping.msn.com/Specs/shp/?itemId=24021913
here is the SUBS
http://shopping.msn.com/specs/shp/?i...amp;fullDesc=1
i'd GREATLY appreciate any recommendations...
Thank You
Old Jan 29, 2006
Slow1pt7's Avatar
Slow1pt7 is an unknown quantity at this point
MTX and Memphis Audio are about the only two companies I like anymore so my suggestions would be either an MTX 1501D or the Memphis 1100D. Any of those amps will supply more than enough power for both of those 8000's.
Old Jan 29, 2006
BlackCiv01's Avatar
thanx man!!!...but if i were to overpower them...would that be bad...would sumtin blow??
Old Jan 30, 2006
Slow1pt7's Avatar
Are those 8000's SVC or DVC? Cause the Memphis 1100D only makes 1100x1 at 1 ohm. At 2 ohms it's only 600x1. Memphis amps actually make the power that they say they do unlike most other amps. You might be surprised just how loud that will be.
Old Jan 30, 2006
BlackCiv01's Avatar
they're dual voice coil...so would the memphis or that mtx amp still good for it??
Old Jan 30, 2006
Slow1pt7's Avatar
The Memphis 1100D would be good. I believe those subs are 400W RMS. Just don't crank the amp all the way up and you will be fine, then you won't be overheating the amp because it's not enough. You would wire the subs like this for the 1 ohm load:
Hope I helped
Old Jan 30, 2006
MegaHurtz's Avatar
you would be fine putting all kinds of power to them as long as you are careful about tuning your system. you can turn your amp up all the way and then some as long as you make sure your signal is very very clean
khmaitiger
Aug 15, 2003 07:38 PM
