Would it be possible to do?
Old Jan 27, 2006
xian's Avatar
Honda > Nissan
xian is on a distinguished road
Do you guys think it would be possible to create a wiring harness to accept audio input from an mp3 player and it work with the stock radio?
At the back of our radio there is an empty harness plug to accept the Honda's stock 6-CD changer unit. I think its a 14-pin plug that is needed. I think it might work considering we have "DISC-" and "DISC+" on the front of our radios.
What I really just want to do is make a harness into the back of the raio, and the other end just have a 1/8" plug to plug into an mp3 player. Do you think with the combination of the "DISC" buttons and the harness I'll be able to do this?
As well, does anyone know what each 14-pin on that plug does?
Thanks
Old Jan 27, 2006
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
if you could get ahold of a wiring schematic or pin out, we could figure out soemthing to work.
Old Jan 27, 2006
fiatdale's Avatar
fiatdale will become famous soon enoughfiatdale will become famous soon enough
I believe there already is an interface out there that will allow you to do an AUX in with the factory deck, check out what PAC makes or Peripheral
Old Jan 27, 2006
05reverb's Avatar
05reverb is an unknown quantity at this point
can't u buy a wire for that? i think they sell em for stock decks too.
Old Jan 27, 2006
MegaHurtz's Avatar
They already make this item
Old Jan 27, 2006
xian's Avatar
Honda > Nissan
How much does this item cost? I don't really want to spend alot on it. I was just wondering if its just as easy to get a 14-pin wire harness, 1/8" male plug and some wire.
Does anyone have know what the 14-pin 6-CD changer plug assignment is? I have the Haynes manual but it doesn't say anything about it.
This could turn out to be a very slick little project. It has tons of potential for other stuff as well. ie homemade mp3player, hehehe, thats the ultimate gone.
Old Jan 27, 2006
MegaHurtz's Avatar
open up the radio and check the circuit board, it may give you some hints as to what the pinout is
Old Jan 27, 2006
fiatdale's Avatar
The interface is like $25. Id that is too much, I wouldnt bother. Youll most likely screw something up inside or mess up a pin or two. I believe Soundgate makes one. Just do a google search
Old Jan 27, 2006
xian's Avatar
Honda > Nissan
I'm trying to avoid that right now, I'm just hoping someone has already done this or someone that already has replaced their stock unit will crack it open for me. Please, anyone? Help me out here.
EDIT: Seagate is like $85 USD!!! Peripheral is about the same. Whats so special about these units?
Old Jan 27, 2006
CenZ's Avatar
PWIT
www.mp3yourcar.com
Old Jan 27, 2006
MegaHurtz's Avatar
whats so special is that they work
personally I would pay 85 for something that gives that kind of feature and is plug and play
Old Jan 27, 2006
xian's Avatar
Honda > Nissan
But I want to know why they work. If it is just splicing wire into another connector I can make this myself for a couple of bucks.
I have another member here going to lookup what each of the 14-pin harness does, and I'll post the results for other members.
If this harness can be made for like $10 AND if it works...boy, have I got some big plans.
Old Jan 27, 2006
HonCivX02's Avatar
HonCivX02 is an unknown quantity at this point
if your not professional then i wouldnt try to create one lol.... im sure there is more to it then splicing a wire
Old Jan 29, 2006
LudlamTheory's Avatar
i boogie for the raindrops
if you send me a stock hu, then i'll check the pinouts for you =)
Old Jan 29, 2006
xian's Avatar
Honda > Nissan
Slightly bad update: My car got broken into lastnight. Nothing missing that I know of. Steering column is all messed up, need some body work done on the door handle. About CND$2000 to fix it up.
This is going to be on the back burner next week now. I'm going to have to open the stock HU up to figure this out. Sorry guys.
Old Jan 7, 2009
bob95065's Avatar
bob95065 is an unknown quantity at this point
Re: Would it be possible to do?
Did you ever get this figured out?
