Front Speaker install - WT@#$%?
Old Jan 12, 2006
dtox666's Avatar
dtox666 is an unknown quantity at this point
Yesterday I went to install some new 6.5" speakers in the front doors of my civic. I removed the door panel, removed the old stock 6.5" speaker and then saw that there's no way in hell to install a new 6.5" speaker: there aren't even any holes in the sheet metal that you could screw into! There are three huge square holes where the "tabs" for the stock speaker snaps into--and that's it!
Is butchering the old stock speaker to use as an "adaptor" the only way to install new speakers?
I'm at a total loss, and any advice/help would be greatly apprecaited.
Old Jan 12, 2006
eye_see_you's Avatar
let the devil out
if you did some research first you would see that a spacer ring is needed to install aftermarket speakers into the civic. There is no adapter or direct fit speaker besides the stock ones. The ring can be made of MDF or ABS plastic
Old Jan 12, 2006
dtox666's Avatar
I did, and I understood about the spacer issue before I started.
My question, is even if I have a spacer how do I mount that to the door when there aren't any screw holes in the door to use?
Old Jan 12, 2006
let the devil out
you will have to drill and make new holes, almost everyone thats installed aftermarket speakers ends up doing this.
Old Jan 12, 2006
LowSky's Avatar
I spend way too much time on this website
LowSky is an unknown quantity at this point
most of todays cars dont use the standard 4 point mounting that aftermarket speakers use. it the same reason that most cars have radio that are built into the dash... it so you dont install aftermarket parts without real difficulty
Old Jan 12, 2006
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
Yup, u can buy them at best buy or some place like that. Then as far as wiring is concerned you can either just hook up or get a wiring harness
Old Jan 12, 2006
dtox666's Avatar
Well I got a new HU, amp, rear 6x9s all installed and running. It's just replacing the 6.5"s in the doors that threw me for a loop...
Guess I'll just try gutting and using the stocks as a spacer and if that doesn't work, then it's off to get some MDF and some very long screws...
Old Jan 12, 2006
burke420's Avatar
The World Is Yours!
well i just screwed some new holes into the existing metal in the door. it took me a while, but i managed to eventually after about 2 hours to get them working in both doors. and they dont touch the door metal.
Old Jan 12, 2006
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
my alpine components came with the spacer for our cars.
Old Jan 12, 2006
MegaHurtz's Avatar
Give searching a try, you need spacers and this has been discussed 1000 times.
cheekyvirgin
Bluetooth
Apr 27, 2015 05:31 AM
ademarco6
Nov 16, 2001 10:19 PM
BabyLX
Nov 16, 2001 05:53 PM
ademarco6
Nov 12, 2001 06:52 PM
JeffSpeed21
Nov 3, 2001 10:32 AM
