LOOKK a system question
well theres a couple of things i got to say,,,, i ran all the wires for my subs and it was all pretty easy. i was wondering though, my power line runs on the passanger side, and well the line for the radio antena is there 2, my power runs right next to it, is that gona screw my reception up and how can i fix this.? also where is a good place to put a bolt for my ground wire? and last but not least , im gona have my box right behind the rear seat, would it sound better if i faced it towards the rear or towards the front, im guessting towards the trunk. thanxx[IMG]i/expressions/beer_yum.gif[/IMG]
i have same setup and power wire doesn't interfere with my radio reception. As far as ground goes, you can ground on the bar right behind rear seats, lift up carpet there and you'll see a bolt to ground to. You should probably put box facing trunk, against back seat, if you use your trunk to put stuff in.
