Wierd amp problem....
Old Jan 10, 2006
HondaKorn's Avatar
Life is better with 5lug
Angry Wierd amp problem....
I know my amp is cheap but it was free....im saving for a good one now but: Ive got a boss 180 x 4 ch going to 6.5 pioneers in the front and bridged to a 15" mtx 5500/5600 on the other channel. It will play fine, then the amp will blow a fuse, but if I disconnect the fronts leaving only the sub connected, then the fuse doesn't blow. Also it seems the bass cuts in and out sometimes but I think thats due to the amp being old and cheap. what do you think....
Old Jan 10, 2006
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
bad ground probably. A bad ground will cause a voltage drop, as the amp is forced to output more power, the voltage drop is going to cause it to draw more and more current to output the same amount of power
Old Jan 10, 2006
Imtheconvict's Avatar
Imtheconvict has a little shameless behaviour in the past
might just not be able to take of load of both try only useing speakers as subs usually need more power
Old Jan 11, 2006
05reverb's Avatar
05reverb is an unknown quantity at this point
probably bad impedence, check how wired and what your amp can handle per channel. if your impedance too low, too much current passing trew your amp
Old Jan 11, 2006
HondaKorn's Avatar
thanks guys....I will check these today....awesomeness!!!
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
