WTF? my system broke, again!
Old Feb 12, 2002
NitehawkVTEC's Avatar
NitehawkVTEC is an unknown quantity at this point
Alright. this is getting really really annoying. i must have the worst luck ever.
i was listening to music the other day, not even that loud. and my sub cut out. never came back. i checked all connections and everythings fine. the amp even gets warm.
I have a Phoenix Gold XS2500, pushing a MTX 8000 12" at 4ohms. it's running bridged so 500x1. it just cut out.... not even on a bass hit.
Old Feb 12, 2002
Rebew1's Avatar
Rebew1 is an unknown quantity at this point
It seems like a lot of people are having trouble with the MTX's. Maybe a wire came loose from inside the box. Or you may have blown a transistor in the amp. Smell the amp and see if you smell burnt plastic. Check the woofer inside and out. Hope you can figure it out.
Old Feb 13, 2002
UncleB's Avatar
UncleB is an unknown quantity at this point
I had a cheap Boss amp running 2 Boss 10"s and one day it just died on me. a friend of mine bought the amp from me to fix it, but he eventually just threw it away. lol. I only got like $10 or something for it.
Old Feb 13, 2002
CIVIC9782's Avatar
CIVIC9782 is an unknown quantity at this point
Try taking a digital multi meter and check the ohms on the sub. See if the subs reads 4 ohms or none if it is blown. or you can gat another speaker and check the amp.
civic9782
Old Feb 13, 2002
yea, i do have another sub. i'll just have to pick it up. is it common for Phoenix Golds to die? I bought it because i thought it would be reliable.
Old Feb 13, 2002
2k2civicballer's Avatar
2k2civicballer is an unknown quantity at this point
check your remote wire or the fuse frmo your head unit.[IMG]i/expressions/beer_yum.gif[/IMG]
Old Feb 13, 2002
i know the amp powers up. the power light comes on! it's either just not putting anything out, or hopefully it's the sub (warranty power).
Old Feb 13, 2002
Hefe's Avatar
Second Place is the First Loser
Hefe is a jewel in the roughHefe is a jewel in the roughHefe is a jewel in the rough
ummmmm......... Check the ground conection for your amp..... Make sure the ground is on good clean metal
Old Feb 14, 2002
i've checked my ground before, when i was having problems with my last setup (2 JL 12w1s, 400watt crap amp), which i entirely replaced, after my amp died, then my subs died. I'd had this system running for maybe 5 days, and now, it's dead. i'm pissed. I'm pretty sure it's not a grounding problem. Mohawkboom, you want to tell me that my Phoenix Gold is dead now? what brand should i try this time, or shoud i just get ir repaired?
Old Feb 15, 2002
Rebew1's Avatar
Have any home speakers floating around the house? Even something small to use as a test speaker? Even try using a mounted speaker in the car with wires that are accessible. Try that before concluding that it is your amp. That will eliminate that question. How old is the amp? If it is more then 5 years you might be better off buying a new one. Parts are cheap but labor is not. Maybe buy a new amp and experiment with the phoenix. You can get most of the parts from radio shack. As long as the numbers of color codes on the resistors are not burn't. Trouble shoot some more. If you have a home stereo take your sub and hook it up to that to test it. Not for long though because most home audio is 8 ohms and you could possibly blow something in that amp. Keep trouble shooting though! Sounds like you have covered half of it.
Old Feb 15, 2002
UncleB's Avatar
<< If you have a home stereo take your sub and hook it up to that to test it. Not for long though because most home audio is 8 ohms and you could possibly blow something in that amp. >>
a friend of mine took 2 15" Fischers from his home stereo and put them in his car. they pounded like crazy. he kept them in the enclosures that they came in. looked really funny when he opened his hatch, but they sounded great.
Old Feb 16, 2002
well, if found the problem. the MTX subs are simply junk. the voicecoil wire's have frayed, and one of them is completely disconnected.
mjdiaz89
Jun 21, 2016 09:26 PM
EM_WON
Jul 22, 2015 06:49 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
EliseKStewart
Jul 15, 2015 11:11 AM
AaronSorenson
Jul 7, 2015 09:40 PM
