where to buy a high-level wire?
Old Dec 17, 2005
stupidspoons's Avatar
stupidspoons is an unknown quantity at this point
I was wonder where i can buy a high level wire/cable? im not taking about the converter to rca thing because thats all i can find. I want just the high level wire/cable from the deck to the amp because i dont have rca on my deck but my amp supports high level.
Old Dec 17, 2005
fallout's Avatar
fallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the rough
What's a high level wire/cable?
Old Dec 17, 2005
the cable that u can plug into ur amp if your deck doesnt have rca, i donno if its called high-level cables but on my amp it has that in outlet as "hi-level" and i search up and ppl said you can either get a high level converter to rca or if your amp supports high level just get a high level cable, but i donno where to get one
Old Dec 17, 2005
MegaHurtz's Avatar
it's called SPEAKER WIRE
high level can also be called speaker level. tap off your rear spekers and run speaker wires to your high level inputs
Old Dec 17, 2005
eye_see_you's Avatar
let the devil out
and its not called high level wire just FYI.. but as mega said yea you can tap your regular speaker wire to a low level converter or direct to your amp if it has that ability.
Old Dec 17, 2005
synod's Avatar
synod is an unknown quantity at this point
http://www.knukonceptz.com/
-where I bought my wire, pretty quality stuff, and not real pricey
juror
Jun 9, 2015 02:15 PM
dpru
May 26, 2015 07:01 PM
Youshoe
May 22, 2015 09:36 PM
nicholaai
Apr 27, 2015 05:54 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
