Running large wire/connector through firewall
Old Dec 10, 2005
MegaHurtz's Avatar
Anybody run anything REALLY large through the firewall? I need to run a connector for something through mine, its about 1.5" wide, but I'm thinking I don't have room anywhere right now, so I'll have to find a route.
Where can I get this connector through? I really don't want to drill if I don't have to, and since the connector is so big I don't want to drill a hole that big anyway. Suggestions?
Old Dec 10, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
rufus has 0awg wire runnin to the trunk, pm him.....or r u going bigger?
Old Dec 10, 2005
skipbarber's Avatar
^1.5" is bigger than 0 awg.
would it be possible to dismantle the connector to get it through? and then reassemble once youre in?
Old Dec 10, 2005
booba5185's Avatar
maybe drill a hole then caulk around it?
Old Dec 10, 2005
MegaHurtz's Avatar
thats a lot of caulk
i cant disassemble the connector, i just tried
where does honda expect you to run the wiring for the OEM fogs? I thought it was thru the fender or soemthing??
Old Dec 10, 2005
booba5185's Avatar
I know that being that big it's not going to be very fexible either way but it it completely stiff or can it move a little? if it can, I'd cut a hole in each side of the rubber connector and try and force it through....
Old Dec 10, 2005
skipbarber's Avatar
OEM honda fog instructions call for shoving it through a grommet on the passanger side, behind the fender. if youre looking at the passangers side of the car, it is where the fender meets the door, immediately behind that is a grommet. You can access it by removing the splash gaurd on the outside, and by removing the kick panel and lower dash cover on the inside.
edit: bellz went through that huge grommet on the passangers side floor/firewall. refer to http://www.geocities.com/bellz252/pdf/diyfoglights.pdf
I'd probably cut the plug, get the wires through and then reconnect the wires.
Old Dec 10, 2005
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
is it possible to snip the connector then resolder it after it passes through the firewall?
Old Dec 10, 2005
booba5185's Avatar
solder 1.5 inches? good god, i would drill before that.
Old Dec 11, 2005
MegaHurtz's Avatar
its a connector with 10 different wires on it. I could, but don't want to solder that many wires lol
Old Dec 11, 2005
turboslug's Avatar
Super Hoser
1.5inches is the size of the connector....good god, i'd read the thread before replying
Old Dec 11, 2005
hawkz99's Avatar
hawkz99 is an unknown quantity at this point
Running fog wires through the grommet? Ah hellz no. I just ran it through the firewall where all the wires go into the cabiin. It's on the driver's side. PM me if you want me to post a pic for you all.
Old Dec 11, 2005
MegaHurtz's Avatar
Post a pic
Old Dec 11, 2005
hawkz99's Avatar
Hmm...now that I look at it again, only one other wire goes through this slot. My fog lights wire go through (for switch) but since it's dark you can't see it. Anyways, this was accomplished by taping the wire with a coathanger and shoving them through. Then from the other side, just feel around for the coathanger and pull the wire through.
Old Dec 11, 2005
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
cut away at the rubber on the passenger side fire wall hole... Ive got 2 0awg wires ran through that ***** trucka! Shove your biggest screw driver through the hole, then duct tape the connector to the screwdriver, then pull away, have a buddy guide it and it should make it through. Hope this helps
Old Dec 11, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
dont wanna drill, dont wanna solder, geez what kinda diy'er are you?
anyway, butt connecters will do the job for you if you wrap them in electrical tape after crimping them on, but soldering would be better.
out of all the options i would have to say that cutting the connector then resoldering it on once you pull the wires seems like the easiest way.
Old Dec 11, 2005
skipbarber's Avatar
there is no way in hell you're getting a 1.5" connector through the heater core wire grommet...
Old Dec 11, 2005
MegaHurtz's Avatar
if I could find a 10 conductor wire I would consider cutting it off
I have another idea... I can take the head of the connector off so that it's just the connector it self and wires, and I could bend the connector so it's parallel with the wire, tape it to the wire and try and shove it thru the firewall
im really not planning on doing this for a while yet, probably in early spring or whenever shows are going to start, but a lot of research is going to be involved to figure out how to get this thing thru.
Old Dec 11, 2005
skipbarber's Avatar
you dont have to, just follow this FULL DIY http://www.geocities.com/bellz252/pdf/diyfoglights.pdf
how much easier do you want it?
Old Dec 11, 2005
MegaHurtz's Avatar
Well, I can't really see where that grommet is, unless its the one I'm already using which I think it is. Also I still havent determined whether or not that or any grommet in our car will allow me to get a 1.5" connector through it.
If that IS the grommet that I think it is, I'm already stuffing a 1/0ga and 10ga wire through it, I don't think I'd have room for another 1.5" connector, but we'll have to see I guess
GolNat
Suspension DIY
May 12, 2022 06:49 AM
WaryDriver
23
Jul 22, 2015 07:18 PM
MamaBear2015
Jun 11, 2015 07:33 PM
mikalem
Jan 5, 2002 10:21 AM
