Quick Electrical Question
Old Dec 4, 2005
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
I'm swapping out the factory stereo for an aftermarket one. Do I need to remove the negative battery terminal? I don't have any tools so this would be a major pain in the ***.
Old Dec 4, 2005
04|5spdCivic's Avatar
Wish I had a Turbo 3)
04|5spdCivic can only hope to improve
try searching before you post. yeah you should take the neg bat cable off. no you wont be able to switch decks without tools.
Old Dec 4, 2005
DeX's Avatar
DeX
Canadian, Eh!
I know I should, but what are the problems if I don't? I already got the deck out, I'm ready to take the hookups off the back.
Old Dec 5, 2005
streetglower's Avatar
anytime you are working on anything in or behind the dash, it is very wise to remove the negative battery terminal and wait a few minutes. You have SRS wiring behind the dash and any mistakes made can cause them to go off. And since you would be in the front seat, you can have your head blown off by the force of the air bags. No joke either.
You dont have to remove the battery terminals, but it is highly recommended.
Old Dec 6, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
if this is your first time doing something like this, then yeah i would def. disconnect the negative battery cable and wait a few minutes while the capacitors for the srs system drain.
Old Dec 6, 2005
jay78's Avatar
jay78 is on a distinguished road
as grenloch said if u know wat you doing then u dont hve to disconnect the battery ....i hve changed mine 3times alrady and i naver disconnect mine...as long as u not cutting any wires....if u got plug and play harness kit then shoudnt be any problem...
Old Dec 6, 2005
MegaHurtz's Avatar
I dunno, i dont think you should have any problems leaving it connected, worst you will do is blow a fuse.
Old Dec 6, 2005
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
I haven't disconnected for just a deck install - but anything beyond it I do.
Old Dec 6, 2005
05reverb's Avatar
05reverb is an unknown quantity at this point
me neither, never took out the battery for just a HU. But i did fry an amp because was too lazy to disconnect the battery, while putting the power wire in it's terminal it touched the amp's metal case and fried it, it's not bad because the i told the store that it was defective and they gave me a new one.
Old Dec 6, 2005
DeX's Avatar
DeX
Canadian, Eh!
All done without problems. I wired up the harnesses before I plugged them in on install so it was all good. The only thing I had to connect after was the ground.
I was hunched over the steering wheel while doing it, if it went off I'd be dead.
Old Dec 8, 2005
coop's Avatar
yup - you learn the hard way once. I haven't fried anything yet myself, but I've seen it happen and it ain't pretty.
Old Dec 8, 2005
coop's Avatar
deck installation is fairly idiot proof - there's not too much to srew up if you can match colored wires.
Old Dec 9, 2005
youd be suprised at some of the abortions i've had brought into my bay.
"but i thought it was going to be easy"
Old Apr 17, 2006
DeX's Avatar
DeX
Canadian, Eh!
Can someone delete this entire thread? Thanks.
BR549
Jun 25, 2015 04:03 PM
thana
Jun 15, 2015 11:58 PM
manicEL
Dec 10, 2001 06:33 PM
viper775
Dec 9, 2001 10:52 PM
MooCoW
Nov 9, 2001 05:22 PM
