Testing RCA, and remote turn on wires??
Old Dec 4, 2005
saugashan's Avatar
This is not my batman glass!!
saugashan should not be trustedsaugashan should not be trustedsaugashan should not be trusted
Hey, how do i test the RCA and remote trun on wire from my deck, casue i have a feeling its not working
casue nothing is
Old Dec 4, 2005
MegaHurtz's Avatar
Multimeter on VDC to check remote wire, should be +12v
Connect an RCA to a multimeter on a low range VAC setting and play a tone at a high volume
Old Dec 4, 2005
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
well if your amp does not power up it is your remote wire, and if it powers up with no sound it is prob. your patch (rca)
and the remote only has power when the HU (deck) is on
if you want you can take a wire and jump from the +12v (batt) and the remote wire terminals and see if it power up, thats another way to test the remote wire thru the process of elimination
good luck
PinkCupcakes
Electronics
Jul 18, 2019 12:50 PM
MamaBear2015
May 3, 2015 02:17 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Juancho007
Jan 20, 2002 10:02 PM
clockwerx
Dec 13, 2001 12:39 PM
