System Problems!!
Old Nov 28, 2005
EmericanElement's Avatar
EmericanElement is an unknown quantity at this point
System Problems!!
Hey. Im new here but I am having serious problems with my system. I have Infinity Referance Components in the front and 6x9s in the back. A Premier 12 sub. To power the door speakers I have a JBL 80.4 and for the sub I have a JBL 1200.1 turn almost all the way down. The problem is that if I am at high RPM the system will get a bit louder and at low RPM my system will get a bit lower in volume. I dont have any idea what this might be. Can anyone help?
Old Nov 28, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
at higher rpm's your alternator also has higher rpm's. so if you know anything about how electricity is made you will understand how this raises the voltage in your car from about 10 at its lowest to about 14 volts. so your car is putting out more power. so since your amps are not batteries if they have more power going in they will have more power coming out. there is no fix.
Old Nov 28, 2005
Well I have had the system in for about 6 months and it just now started to do this. It is a pretty big jump in volume. Big enough to blow my fron two speakers. Is that all that it can be? And does everyone have this problem then?
Old Nov 28, 2005
nick95673's Avatar
if its dramatic as that pull out a multi meter and read the voltage at 3krpm and at idle. if it stays in the 10-14 volt range then have your amp checked i hope you bought the extended warranty on your amps. if its outside that range have your electrical system checked.
Old Nov 28, 2005
ok thanks alot
Old Dec 2, 2005
yourpalmike's Avatar
yourpalmike is an unknown quantity at this point
who installed your gear?
CarStuff
Dec 6, 2020 12:52 PM
dinsum
May 28, 2015 09:30 PM
Youshoe
May 22, 2015 09:36 PM
crowtoo
May 11, 2015 06:50 PM
tylerginevan
Apr 27, 2015 12:29 PM
