Subs and the cold
Subs and the cold
As winter is almost here I have a question about subs and cold weather. Is it bad for them? some people have told me that it can break them but I have no clue. I just picked up a sub off my friend and im wondering if i should wait until spring to put it in. Its a punch 10" dvc, i just picked it up for some extra bass. thanks in advance.
the colder, the easier stuff breaks, for example the rubber on the sub, when freezing outside, the rubber gets stiff and if you crank it immediatly, it might rip, maybe also the tinsel wire. I don't know if it's really neccesarry to take it out for winter, if you warm it up before turning it up loud. I always take out my complete system out, just did it this weekend, because some days can be pretty cold down here. i was especially worried about my LCD screen, subs aren't that bad if you watch how you use it in the winter. but since u don't have it in your car already, i would wait to put it in, because i know that i don't spend more time in my car in the winter than neccesarry, unless u drive alot in the winter.
you dont need to take it out.
just dont blast it right away. let your car heat up a bit and while its doing that play at very low volumes and thern after a while u can let er rip
yeah you just need to let the coils warm up before you turn it up thats all. but rubber doesnt really freeze till you get below zero, but like any other day always let your system warm up before you crank it.
Slowest 7thgen in the GTA
I drove all winter with my system in my car. I don't think I can stand listening to music without my sub even at low volumes. I'd rather risk breaking my VC on my sub than take it out for the winter.
As long as you don't crank up the volume like everyone else said, you should be fine. I still have the same sub as I did last winter, and it still pounds, and no damage yet. As long as you are smart about it, you should have no worries.
Originally Posted by SlimmKidd
I always take my JL W3 v2 out EVER Winter I would rather go without them for three months than have to replace them not to mention my amp and deck.....
The only decks I've had problems with in the winter were stock decks, and never aftermarket ones. I've used decks on the coldest days where my temperature gauge on my car would not go up after driving for 30 minutes, and still used my system, and it worked fine.
Taking out your system for winter is overkill if you ask me. Just don't abuse it, and let you subs warm up before you starting pounding them. Use at low levels first and then turn louder slowly.
On really really cold days I would not turn them up loud at all. If you keep them at low levels on these days, you should be fine.
Originally Posted by 2k2_civic_ex_4d
Oh man I'm glad I live in perfect San Diego, just my .2 cents.
but really having the system in your car in the winter is no problem at all, like stated above, just ease it in and be smart.
ive never had a problem and im liek 99% sure i never will
i took mine out about a month ago. after rereading all of those posts i'm thinkin about puttin it back in cause i miss it a whole lot. and i agree, not by experience but just thinkin about it, if you take it everthing thing should go over pretty well.
Yes thanks guys I was actually thinking about putting them back in cause my car is so dead now w/o them and it has been really warm in Toronto (above zero for the past two weeks)
juicetayne
Sep 30, 2015 11:02 AM
