speakers
Old Nov 25, 2005
Imtheconvict's Avatar
Imtheconvict has a little shameless behaviour in the past
speakers
from people who have changed there stock speakers has it made a difference if so how and what did u replace them with
Old Nov 25, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
the search button.
Old Nov 25, 2005
booba5185's Avatar
but if your lazy (as i am at work), i Replace stock poop with Infinity Kappa components, i had to bend and cut the metal around the 6.5s then take the mount and grille that came with the 6.5s, turn it around, and use that as the spacer so my windows would roll down. The tweeters, i had to cut holes in the door using my trusty dremel tool. then mounted the crossover in the door using zip ties. Was it worth it? Is it worth it to wear a condom when f*cking Pamela Lee? Same answer. Of course, U'll need an amp to power any type of decsent speakers, so take that into effect, too. With those 2 combind, it makes a world off difference, one of the best things i ever did to my stereo.
Old Dec 2, 2005
yourpalmike's Avatar
yourpalmike is an unknown quantity at this point
HUGE difference.
best thing you can do to upgrade your sound system.
Old Dec 2, 2005
MegaHurtz's Avatar
search and you will find a lot of info
Mad Dog Tannen
Oct 19, 2016 08:12 PM
UltraHDGames
Jun 8, 2016 05:16 PM
meicalnissyen
Sep 25, 2015 12:12 AM
Gsxtacy
Sep 12, 2015 01:09 AM
redcloud
Sep 7, 2015 01:45 PM
