snailshell fits in a civic
Old Nov 13, 2005
chriscivic's Avatar
chriscivic is an unknown quantity at this point
just letting you guys know that a p4s snailshell for a 15" xxx does fit in a civic. i built one this weekend for a guy on sounddomain and it turned out great, it took a little bit of trouble to get in the civic but it does fit. i had to take out my trunk floor (3/4" mdf) to get it to slide in. i got pics but i am having problems loading them onto my computer. and if anyone wants one built i will do it or aaany other type of box. btw my car is an 02 sedan
Old Nov 13, 2005
manahoonie's Avatar
ummm, wtf are you talking about?
Old Nov 13, 2005
wheamahm0n3yat's Avatar
wheamahm0n3yat is an unknown quantity at this point
^^^ word
Old Nov 13, 2005
BERGER's Avatar
BERGER will become famous soon enoughBERGER will become famous soon enough
the box for a resonant engineering 15" XXX you need a big box and he fit one into a civic...
Old Nov 13, 2005
usafcushman's Avatar
7thGen's Loudest Civic...4,000 watts and climbing...
usafcushman is on a distinguished road
thanks, bro... i've been losing sleep over that ish for months... i feel much better now
seriously, though, this is kinda an unneccessary post... i mean, if i can fit 62 Memphis 10"s in a Chevy Celebrity station wagon, 1 15" in a snailshell should fit in a 'Vic... just my $.02 (even though it was unneccessary as well)
Old Nov 13, 2005
chriscivic's Avatar
well this is not a celebrity station wagon forum so who cares, your post was unnecessary. and it "should" fit in a vic, i am sure honda designed the trunk just for that.i was just letting people know that might want as snailshell. i got some pics of it in the civic but am having trouble getting them on my computer.
Old Nov 13, 2005
chriscivic's Avatar
external is 33x21x17
Old Nov 13, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
dont like using a router?
Old Nov 13, 2005
chriscivic's Avatar
if you are talking about the hole, i think i did pretty good with a jigsaw
Old Nov 13, 2005
hdave's Avatar
hdave is an unknown quantity at this point
u did great with a jigsaw
i did a much crappier job and had to sand a whole lot of wood
and can you please compare that snailsheel to a regular ported box?
Old Nov 13, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
That's not a snail shell enclosure. It's a transmission line enclosure. Primary difference is that this is not a snail shell shape. The reason that this enclosure (made popular by companies and shops, some including Virtual Technologies(now defunct) and Sound Sensations in Marietta Ga's wavebox) is effective is because it is a wave guide system where the guide reverses thephase of the driver's rear output, reinforcing the frequencies near the driver F's. They tend to be larger due tosize and length of the line required by the design. Benefits are extended low end response. Drivers usually suitable for transmission line type enclosures are ones that have low Qts, Qes, and Fs.
Some more resources about this type of enclosure:
http://www.quarter-wave.com/
http://www.t-linespeakers.org/
http://geocities.com/rbrines1/
http://www.hogheaven.com/diyaudio/su...PATL/patl.html
The best snailshell I have ever seen is a cochlear design used for home audio for a single 12. It's on the net somewhere, and is black and huge. It also highly looks like a snail shell, minus the color. All glass too. Nice *** enclosure, but won't fit in a civic, or any other smaller car.
Old Nov 14, 2005
just another shot of a P4S SnailShell box... this is for a 12" subwoofer, and as you can see it pretty much takes up the entire trunk of an Infiniti J30... not saying it's impossible, but i bet it would be a bitch to get a SS box for a 15" into a 'Vic... coincidentally, the sub in the pic is also a RE XXX...
Old Nov 14, 2005
chriscivic's Avatar
it think i know what i am talking about, i built it and put it in my trunk, it is an exact copy of a p4s snailshell. external is 33x17x21. it is over 5 cubes external. it does fit and i will get the pics asap.
Old Nov 14, 2005
sorry bro, i apologize... i didn't really pay attention to the top pic, and i didn't notice that you had mapped out the internal structure... when i was looking at the bottom pic, it didn't look like the port continued to go around and along the back of the enclosure after that angled piece ...
again, sorry i was a d!ck about it... it was 2 a.m. and i was a lil blitzed, and i have a tendency to talk $hit... my bad... i also edited my post above cuz i'm no longer doubting you...
in retrospect: AWESOME job on the box... cuts are perfect, good seal, props on the countersunk screws... +1 rep for the info...
Cliff's Notes:
me = , you =
Old Nov 14, 2005
chriscivic's Avatar
no problem , i know i d!ck about it too, but you were leading people to think it was not a real snailshell. and do you have l7's? i was wanting to do two 15" l7's in about 3.5 cubes a piece, i have come up with a design that will fit this in my trunk, but was wondering if it was enough volume for l7's? going to power them off a modded bd1500 ~1800rms. my friend said this was not enough power for two?
Old Nov 14, 2005
yeah, i'm running 4 S12L7s off of a pair of modded KX1200.1s (~1600 watts each)... i'm running them in a 4-chambered sealed box, and it's somewhere around 8-9 cubic feet of airspace... it's mostly fiberglass, so i'm not 100% sure of the box volume...
anyway, are you going to run sealed or ported?... holla if you need any help designing a box or anything, i'd be glad to help ya out... check Kicker's web site for recommended box specs...
and as far as the amp issue is concerned: i'd say the bd1500 is perfect, even if it wasn't modded... the S15L7s are 1000w RMS / 2000w peak, so ~900 watts to each of em should be enough to slam without overloading them...
good luck with your setup... holla if you need any help with anything...
Poopies
Apr 20, 2017 11:36 PM
BreezeNine
Apr 14, 2015 05:41 PM
aus10
Apr 13, 2015 09:26 PM
civicPRODIGY
Nov 12, 2001 06:33 PM
SleepyT
Nov 1, 2001 04:59 AM
