question about door speakers
Old Nov 7, 2005
rabid_sloth's Avatar
rabid_sloth is an unknown quantity at this point
Exclamation question about door speakers
I recently had my stock speakers replaced by infinity refrence 6.5's both front and rear. I had them dynamat the doors and rear deck. Problem is that now the rear speakers sound much louder than the front ones. The only way to get the Front to Rear balance to sound right is to adjust it on the head unit. The only difference between the front and back speakers is that the front ones are shallow depth speakers. Anyone have any ideas what could be wrong, if anything? I have a pioneer 4x50 watt head unit if that matters.
Old Nov 7, 2005
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
i have no idea. did you check all of the connections? positive and negatives are correct? what are the rms for the front and back?
if everything seems ok, just fade it to the front about 1 or 2 clicks.
Old Nov 7, 2005
LowSky's Avatar
I spend way too much time on this website
LowSky is an unknown quantity at this point
the shallow depth speaker are rated a little lower than the rear speakers. so you will need to fade the speakers foward to even out the sound.
Old Nov 8, 2005
Thanks for the Help!
Thanks a lot. I have some issues i am working out with the installer.... For now, I will adjust the front/back balance to compensate.
Old Nov 8, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
the front speakers could be out of phase with the rears
Old Nov 9, 2005
ryankne's Avatar
ryankne is an unknown quantity at this point
i installed infinity 6.5" in the front doors, and rear......w/ an amp.....my front speakers sound quieter and have a little less bass.........i think this car always sounds like that with aftermarket speakers......its just the way the door is shaped, and how the speakers are mounted.......also the factory front speakers have a plastic enclosure which might make them sound a little louder in the doors......i just adjusted my amp to have the front speakers turned up a little bit louder than the rear.......
Old Nov 10, 2005
82801BA's Avatar
82801BA is an unknown quantity at this point
Not only this car, but I've seen most cars are like that unless a complete factory system is used.
The best bet will be fading, then adjust the phase of front/rear to make the sound together at the front.
Old Nov 11, 2005
legacyse's Avatar
legacyse is an unknown quantity at this point
i've got a question about the speakers also... do you need the foam and the metal brackets/adapter in order to install the speakers? I'm missing both of them... thx
Old Nov 11, 2005
you guys did something wrong with the install. i have the same speakers 6.5 infinity all around, amped, installed, with cheap alpine HU. I also have tweeters running off deck power but even without them the speakers are pretty balanced. The rear will be slightly louder due to the car shape, but I haven't found the need to fade anything. Maybe you just need tweeters? The speakers are great, on some trance songs the bass is clear and loud enough to rattle the mirrors.
Jeffdp
Aug 5, 2015 11:38 AM
Jeffdp
Jun 18, 2015 06:18 PM
h4ldol
Jun 3, 2015 03:26 PM
supercivic01
South
Nov 30, 2001 11:27 AM
doublins
Nov 11, 2001 07:01 PM
