Does anyone ever notice...
Old Nov 7, 2005
bigmurr's Avatar
Downed but not for good
bigmurr will become famous soon enoughbigmurr will become famous soon enough
Does anyone ever notice your headlights dim a good bit when you turn the A/C on or maybe even the heat?
I've noticed it for awhile and it just makes me mad. Is it normal if so what causes it? If not what do I have to do to fix it?
Old Nov 7, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
yes it is normal. Your alternator and battery can only give you so much power. So the more items you have running off your electrical system at once the less power everything gets.
Old Nov 7, 2005
bigmurr's Avatar
is there any way to make it not so bad?
Old Nov 7, 2005
nick95673's Avatar
upgrade your factory grounds to 4 awg and buy a deep cycle battery. But nothing will eliminate it. Because your a/c will work better than it did b4 but when you turn on the radio and headlights a % of the new more power will go to the other items. so your a/c may be working better with the new bat and grounds and everything on but you will still notice the a/c weaken when you turn on acc.
Old Nov 7, 2005
bigmurr's Avatar
can you send me in the right direction to buy those grounds. thanks alot nick95673
Old Nov 7, 2005
Royando's Avatar
Royando is an unknown quantity at this point
retrofit some valeos in some TYCs, a good HID kit, and then try it
Old Nov 7, 2005
nick95673's Avatar
http://www.7thgencivic.com/memberrid...imageuser=8177 this wire replaces the stock engine ground. then run another wire from the body to the negative terminal battery.
http://www.7thgencivic.com/memberrid...imageuser=8177 then run this ground back to the negative terminal on the battery.
http://www.7thgencivic.com/memberrid...imageuser=8177 then run another wire from the tranny to the negative terminal battery.
http://www.7thgencivic.com/memberrid...imageuser=8177 thats what your battery terminal should look like when all is done.
just buy some 4 awg from a local stereo shop and (8) 4 awg ring terminals.
you can also buy an hvs kit.
^all are from gearbox's pics
Old Nov 7, 2005
nick95673's Avatar
o and look gearbox is getting rid of his hvs http://www.7thgencivic.com/forums/sh...d.php?t=234029
Old Nov 7, 2005
bigmurr's Avatar
thanks I knew I saw those pics somewhere that helps alot I think I might try it since it seems real easy and cheap.
Old Nov 8, 2005
performance sys's Avatar
performance sys is an unknown quantity at this point
I have some blue 4awg wire in the shop, $.99 a foot, however much you want. Ring terminals with black or red cover sleeves, $.99 each.
I also have ground distribution blocks that you can tie all grounds to and then run a lead to the battery if you want, give me a few min to get the images uploaded and I'll post pics and prices.
Old Nov 8, 2005
Okay, here's the ground block I have available:
Six 4awg ports, One 0awg port. You don't have to use the 0awg port if you don't want to, but if you locate the block close to the battery, you won't need much 0awg wire.
Wiring Supplies has the wire and ring terminals you can use to build your own ground kit.
Old Nov 8, 2005
leviathan18's Avatar
leviathan18 is an unknown quantity at this point
you can run a bigger alternator or deep cycle battery also if you have amps you can add a capacitor
Old Nov 10, 2005
82801BA's Avatar
82801BA is an unknown quantity at this point
My voltage drop from 13.8V to 11.8V at full throttle with A/C OFF. The deeper I press the pedal, the lower it drops. But even I hit the pedal a little bit it still droped to 12.4V. When I turn A/C on, the voltage doesn't drop, what's wrong?
Old Nov 10, 2005
EM2typeflex's Avatar
EM2typeflex is an unknown quantity at this point
Funny that you mention this, when I'm bored, I flick the window swithces for the driver and passanger windows at the same time to see the light dim. I noticed that since I first got the civic, and I still find it funny that these cars do that.
Old Nov 10, 2005
bigmurr's Avatar
yeah well all of little things here and there running I didn't realize that it could draw that much power to see a difference with the performance of those things.
I really hope that by upgrading my grounding wires it will lessen the problem.
el_ben2
Apr 19, 2004 11:01 PM
OniChi
Vancouver
Mar 24, 2004 09:22 PM
Dticalman01
Jan 30, 2004 01:09 AM
