Mounting amp under front seat
Old Oct 30, 2005
MegaHurtz's Avatar
Anybody done this? What did you do to secure the amp?
I am probably going to put a small amp for my midbass under my passenger seat in the near future, just doing some advance research
Old Oct 30, 2005
Mike04Civic's Avatar
Mike04Civic is an unknown quantity at this point
ive got my amp under my passenger seat,...not "mounted" to anything,...but it doesnt go anywhere,..soo not that big of a deal to me,...and has good ventilation so no serious overheating problems with it being there.
Old Oct 30, 2005
cmeias's Avatar
cmeias is an unknown quantity at this point
I have one amp under my passenger seat and one under the drivers seat. They have been there for about a year with no problems. I say if it fits and doesnt rub when you move the seat back and forth then put it there it will be much harder to steal if your car is ever broken into. I mounted my amps with 2inch sheet metal screws. They stick out the bottom of the car but are not noticable unless you look for them.
Old Oct 30, 2005
performance sys's Avatar
performance sys is an unknown quantity at this point
Using 1" self tapping sheet metal screws works just fine, and won't stick out of the bottom of the car. Remember, you're not supporting the entire weight of the amp in the air (as if you were mounting to the underside of the rear deck), so you don't have to go nuts on screw size to mount the amp. There shouldn't be anything under the car to hit, but just look and make sure especially if you have added any nitrous or fuel lines to your car.
Just a note for anyone that might mount an amp under their driver's seat- if you have an adjustable seat, check clearance with the seat all the way down!
Old Oct 30, 2005
leviathan18's Avatar
leviathan18 is an unknown quantity at this point
i have my amp under the passanger seat and my cap under the drivers seat everything is fine... just check you dont scratch it when you move the seat and you will be fine...
Old Oct 30, 2005
MegaHurtz's Avatar
I know people have done it I am just wondering what they did to secure the amp down....
performance, are you saiyng you drilled right thru the floor? if i do that, how will the screws not stick right out the bottom of the car?
Old Oct 30, 2005
eye_see_you's Avatar
let the devil out
I have my clarion head unit brain under the seat along with a 6 disc changer and a small amp and no issues at all.
Old Oct 30, 2005
civic_newbie's Avatar
civic_newbie is an unknown quantity at this point
I was thinking of doing that, but using self adhesive Heavy Duty Velcro....just stick it to the amp and it'll stick to the carpet under the seat...not a big fan of drilling through the car...but prob not as secure...oh well
Old Oct 30, 2005
I used 1" sheet metal screws, and about 1/4" stuck out on the bottom, I just hit those exposed points with a dremel cut off wheel. If your amp has thick mounting points, it may not stick out at all, this was a Lightning Audio amp that has thin mounting tabs. That's what I was saying about not having to use a long screw, you're not supporting the full weight of the amp, just holding it in place, so you don't need a long screw to make it work.
Old Oct 30, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
if Im mounting something under a seat I usually try to slide a piece of wood under the carpet so I can avoid drilling holes into the body of the car.
Old Oct 30, 2005
MegaHurtz's Avatar
That occured to me.
The idea I did have is wait until I do my sound deadening install (won't be for a while) and put a piece of 1/2" mdf under both the seats while everything is out of the car and then silicone em down.
Old Oct 30, 2005
I like that idea... the sound deadener keeps the wood in place and no holes drilled in the car.
Good idea.
Old Oct 30, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
At the very least, I'd put a spacer under the amp to lift it off the carpet ever so slightly. The cooling fins, most likely, are going to be on the ends, but under there, the ones in the back will be fine as far as cooling, but the ones up front might reflect some of the heat back to the amp because of that small bump under there. Raising it a tad might make at least the top half of the fins functional. Plus, it'll allow the bottom side of the amp to get a little ventilation. Still, might not be a bad idea to put a cpu fan or two under there to aid in cooling. Don't want the amp going all thermal on you being a competitor.
Old Oct 31, 2005
very true
Old Oct 31, 2005
dapakione's Avatar
dapakione is an unknown quantity at this point
did anyone mount an amp or a capacitor under the trunk where the spare tire is, i know my friend wit an 05 legacy lgt mounted his jl audio amps ova there, so i was thinkin of doing the same thing......
Old Nov 1, 2005
my previous setup I had twp amps, a cap, two distro blocks, and my crossovers all crammed under there with the spare tire, didnt look too pretty but it worked. Now I just have my power distro and my capactior under there.
Old Nov 1, 2005
dapakione's Avatar
I just want to put the distributer, the capacitor, and the interior amp (alpine v12) under there, the sub im using is the infinity basslink, and it has a built in amp, so i wont be having two down there just one..... i do want a clean set up, and my dad drives the car around alot, and hez old, so i need to make sure that if worse comes to worse, he can get the spare out when he needs it....
Old Nov 2, 2005
My setup under there was anything from clean. If you want to cram everything under there and still keep the spare your going to have to sacrifice asethtics. I took a FG mold of the wheel well, cut out the part where the spare sits and then attached all my mounting points straight to the fiberglass. It was a little flimsy since I only did two layers, but it worked.
Old Nov 2, 2005
dapakione's Avatar
is this possible
making a whole new wood floor board, putting a hinge on it, and bolting everything against that wood (floor) and compensating for the screws not going thru to the other side, so when i left it i can adjust it when i lift it up like a door. does that even make sense, i dont know what im saying anymore
Old Nov 3, 2005
you mean mounting the equipment to the underside of the board, so when you look in the trunk all you see is a normal looking floor? it can be done, but your going to need alot of ventilation since your bypassing the heatsinks
Old Nov 3, 2005
dapakione's Avatar
i dont know, i have the cap installed, im doing the speaker work over the summer, ill draw out a sketch with dimensions and try to figure it out on my own right now im just waitin for my semester to end, then if the weather iz okay ill do it between semesters, if not im going to wait till spring...... but ill try my best to do a clean install, and ill post up pics if it comes out nice, thanxs for the advice tho
Old Nov 5, 2005
no problem, hope it comes out great. I know the feeling about waiting till the semesters over to do some work. i've got springs and shocks sitting in my room staring at me, no time to install them till i get a break at school
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Supramk3
Jun 11, 2015 11:13 AM
em2_k20a
May 19, 2015 03:36 AM
GH04si
Apr 15, 2015 08:13 PM
SimDogg
Nov 27, 2001 04:20 PM
