Running wire through seats for headrest LCD
Old Oct 29, 2005
MegaHurtz's Avatar
For those who have installed headrest LCDs in their car, how did you run the wire through the seats? I am expecting these http://cgi.ebay.ca/2-x-INNOVATEK-IN-...QQcmdZViewItem soon so I need to decide how the wire is going to be run thru the seats.
It doesn't look like the wires for the headrests come out the post, so I will have to find a way to get it from the headrest into the back of the seat, and then do something else to get it out the back of the seat at the bottom. I was out in my car earlier to see if there way a way I could get the back of the seat to come off, but I didn't meet with any success.
If anybody with some experience with this can give me a bit of a rundown or supply any little tips that will help me, it's much appreciated
Old Oct 29, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
i'm at work so i cant see but i think there is a zipper of some sort at the bottom of the back of the seat, if not, use a metal coat hanger and run it down, poke a hole and run ito through the center console
Old Oct 29, 2005
MegaHurtz's Avatar
i don't see a zipper anywhere, but it looks like there is some kind of clip or something holding the back of the seat on... but I couldn't figure out how it comes apart or comes off or whatever.
Old Oct 30, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
My 01 with leather had a zipper. I would, however believe, should there not be a zipper, it's have a u-channel thing much teh same as the rear seats. May be a zipper on each side that is about 4 inches long or so. I'd drill out the headrest post if necessary, and run the wire through and out the bottom into the seats.
Old Oct 30, 2005
manahoonie's Avatar
the zipper is tucked in near the bottom of the seat back. on the back of each seat, you should see what looks like a zipper running vertically, one on each side. down at the bottom, the zipper is tucked in.
Old Oct 30, 2005
manahoonie's Avatar
whoa! deja vu (at least the first five words on each line in my previous post! lol)
Old Oct 30, 2005
MegaHurtz's Avatar
I'm positive I don't have any zippers... I ran my hand all over the seat and couldnt find anything, but it does seem like there is something holding the back together that I can't figure out.
Old Oct 30, 2005
MegaHurtz's Avatar
nevermind i just went out there again and I got it. There was like a plastic bar thing like attached to the bottom of the back of the seat and a hook sorta thing that was attached to the part that came down from the fornt and back up underneath the seat. the bar for the back part of the seat kinda wrapped around and back up and hooked into the other part. after I got that I could reach up to pretty much the top of the seat.
still have to deal with getting the wire into the seat though. I don't think putting it thru the post will work too well, the problem would be what would I do when I try to get the RCA plug through?
Old Oct 30, 2005
Caucasian.Asian's Avatar
well, do you have your headrest all the way down or is there a space between the headrest and seat? if its against the seat just get a knife and poke a hole big enough for the wire to run through it. if its only a slit in the fabric it will be naked to the eye. and if you're worried about the hole increasing in size, just get your moms sewing kit and sew the edged of the slit to prevent it from expanding.
Old Oct 30, 2005
MegaHurtz's Avatar
I would have my headrest all the way down I would think. I thought about that too, and that is what I will probably do. I don't think the slit would spread becuase I would never touch that area otherwise, it will always be covered by headrest, but it is the principle of cutting my seat that I don't like, but it might make things a helluva lot easier.
Old Oct 30, 2005
manahoonie's Avatar
you can also see about getting the wire to go in under one of the plastic pieces from where the 'poles' come out of. not between the pole and plastic, but between the plastic and the seat fabric...
Old Oct 30, 2005
fergsonfire's Avatar
Kung-Fu Kar Kare Master
fergsonfire is an unknown quantity at this point
might I reccomend for placing the rca cable through, just taking it apart and then soldering it back together. I know this is not the "easiest" method, but probably the best results. Well I guess that requires knowing how to solder huh. Nevermind disregard everything I have just said. Probably too hard for most people. Stupid electrical training. Makes me think this stuff is common. Yeah, no idea. Wooo rant and rave, yeah!
Old Oct 30, 2005
MegaHurtz's Avatar
yeah I looked at that too, it might be possible, I'm bored right now I think Imma go out there and **** around
Old Oct 30, 2005
MegaHurtz's Avatar
Yeah soldering is tough. BTW you DO realize that I run the electrical section of the board, right? I can handle me a bit of soldering
I've actually considered that too, but I am not tickled pink about soldering inside my car and risking ****ing up my interior. Not that I would, but it's a bad situation waiting to happen.
I was just out in my car and it looks like I will have to cut the seat a little bit to fit the wire through, I tried to stuff the RCA end through the area around where the pole goes in and it wasn't happening. I could ALMOST fit the rca cable right down the hole for the pole, but not quite
I might be getting a bit ahead of myself though, I don't even have the headrests here yet. I'm sure once they are in my possession it will make it far easier to find a solution.
Old Oct 30, 2005
I'm thinking you decided to go with a sedan headrest. Regardless, Should you decide to run the RCA's through the headrest post, you might want to get some 8 inch or so RCA extenders/connectors and cut them and solder them, then you plug them to teh ones already on the monitors. That way, tou can't fvck up your monitors. You only risk losing the RCA's that you cut and soldered. Plus, you could, thoretically, solder outside the vehicle. Cause once you get them through the headrest you'd simply have to plug them up.
Old Oct 30, 2005
MegaHurtz's Avatar
hrms, looking at the picture on this page http://www.mp3playerstore.com/stuff_...ial/IN-737.htm it looks like the wire already comes out the bottom.
Looking at these different but similar monitors http://www.mp3playerstore.com/stuff_...ial/IN-727.htm you can see the plug... I just hope that the plug is small enough to fit thru the headrest hole on the seat
Old Nov 3, 2005
MegaHurtz's Avatar
w00t
got em today and they work quite well, picture isn't bad at all. test fitted em in my car, the plug on the end of the wire fits right into the headrest hole, seems like its gonna be a no hassle install
Old Nov 3, 2005
Supermanrider's Avatar
I dont know what im talking about
Supermanrider is an unknown quantity at this point
look nice hope they as good installed
Old Nov 3, 2005
MegaHurtz's Avatar
i put em in my car quickly to check em out, they looked pretty good, especially given that I have cloth seats. the color diff wasn't that bad.. but I will have some pics up as soon as they are installed and wired, which I am hoping will be this weekend.
Old Nov 4, 2005
jay78's Avatar
jay78 is on a distinguished road
dude hre some pics of mine
and while i was taking this pics when i pullup my headrest i think the wires wasnt enought to pull the headrest all the way up...and now i am getting little black line...going...from top to bottom....any know how to fix....as long as i think is one of the wire got messed up when i pull the headrest...too hard..
Old Nov 5, 2005
MegaHurtz's Avatar
installed
I have power going to them, but no signal yet. The video amplifier is sitting in front of me, it's going in tomorrow or Sunday.
Old Nov 5, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
Originally Posted by MegaHurtz
installed
looks nice, might as well add a drop down screen in there too
Old Nov 5, 2005
boombazokajoe91's Avatar
I survived that B*tch Katrina !!!
boombazokajoe91 is an unknown quantity at this point
looks tight.. let me know how those tvs are ...i was scared to buy those from that site..... i found 5.6 monitors already in tan sedan headrest for 300.... i might get them instead
Old Nov 6, 2005
jay78's Avatar
i like mine
only problem is....u have watch it straight only...its not that good when u are watching from side......but not bad for the prise....i paid mine 200.00 shipped..
Old Nov 6, 2005
MegaHurtz's Avatar
they seem to be pretty good so far. they work great from all angles from what I have seen so far, and if the person in the back is at a wierd height, the headrests tilt up and down
Old Nov 6, 2005
MegaHurtz's Avatar
Done!!!
Some videos:
http://www.2k4civic.com/video/civicvideo1.avi
http://www.2k4civic.com/video/civicvideo2.avi
http://www.2k4civic.com/video/civicvideo3.avi
Old Nov 6, 2005
booba5185's Avatar
damn u, i wanna watch harold and kumar now, as*hole, j/p
Old Nov 6, 2005
im debating on gettin those or HIDS right now....
Old Nov 6, 2005
MegaHurtz's Avatar
A couple more for good measure
Old Nov 7, 2005
jay78's Avatar
look nice mega....your visor screens are much better then mine....looks good from evey angel...keep it up
