lightweight pulley with HO alternator ?
Old Oct 26, 2005
K20A_Wanabe's Avatar
K20A_Wanabe is an unknown quantity at this point
Alright first things my system is 2200 watts peak, so is it posable to get a HO alternator and then put a pulley kit on the car with out screwing up my wattage or would that ruin the alternator?
Old Oct 26, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
seems counterproductive. Pulley kits underdrive the alternator so its less of a parastic draw on the engine, which results in less amps being put out. Gotta choose if you want more engine power or more electrical power.
Old Oct 27, 2005
No what i meant is that instead of me geting a 150a alternator i would get a 170a alternator, so then i would put a lightweight pulley on. But when i read aem site it says it's at oe spec but light, so does that mean i won't loose voltage or amp? My friend said these pulleys make your alternator and powersteering work hard because it's turnning fast, but i though i just turns easier, doesn't ?
Thanks
Old Oct 27, 2005
I thought you were talking about the undedrive pulleys which reduce the output of all your accessories. If the pullies are to OE spec, i cant see a problem with it. What are you going to be running to require an alt upgrade?
Old Oct 27, 2005
I just have 2 amps one is 1000 watts peak and other runing 1200 watts peak
Old Oct 27, 2005
whats the fuses on them?
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Bonobo
Oct 2, 2015 06:58 PM
ken4444
Sep 30, 2015 07:37 PM
260000milesgoal
Sep 25, 2015 07:41 PM
speedlever
Sep 24, 2015 07:18 PM
