Speaker Tinsel\woven wire
Old Oct 18, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
Anyone have the slightest clue where to buy speaker tinsel or woven wire? I started a thread awhile back about how my speaker tinsels keep breaking and how i cant fix it, I've tried solder wick because it's woven, but the main problem with solder wick is that fact that it's made to absorb solder...then the solder moves too much with the cone, and the friction causes it to break, what i need is some sort of woven wire that that use on tinsels at the factory so it wont absorb any solder whatsoever and move freely with heating up and breaking, any ideas?
Matt
edit: Here's a pic of what i could get....sorry about the quality, kinda of a small space lol
i clean all solder off everytime and use fresh wick everytime too...i think i've redone it about 25 times now lol.....it's pretty obvious by now i will not give up til it's fixed hehe
Old Oct 18, 2005
joe6680's Avatar
joe6680 will become famous soon enoughjoe6680 will become famous soon enough
what if you attached one of these then added some shrink tubing to help keep the wire in tact. Just a suggestion.
Old Oct 18, 2005
booba5185's Avatar
i thought of that to, but the prob is it needs to move fast, I'm sure u've seen how fast and how much a sub moves, it's the wire that goes from the connector to the cone....
Old Oct 18, 2005
MegaHurtz's Avatar
can you solder a pair of wires right to the voice coil? liek speaker wire, not tinsel.
Old Oct 18, 2005
booba5185's Avatar
tried that too, it moves to fast and breaks it.....and it's not that i have anything turned up too loud or anything like that, i listen to rock so not really that many sustained tones, just the kick drum...i've had to fix it atleast once a day (sometimes twice) for the last 2 weeks....I've got soldering it down to an art now
Old Oct 18, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
I've never dissected a tinsel lead, but from looknig at it, I'd imaging it's a piece of woven wire with no core. With that in mind, if you could possibly find some high quality (meaning it'd conduct well) then maybe you could use wither a piano string (one of the thick ones of course, not the ones that are thin like a hair) a guitar string or maybe some picture hanging wire. Possibly find one with some sort of coating such as gold or copper. Don't know, just an idea.
Old Nov 14, 2005
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
i've tried two pieces of solder wick in parallel and it worked fine..i purposely made it extra long and also wrapped the wick w/ heatshrinktubing for extra support...you have to be good at soldering so you wont get a cold solder joint or too much solder onto the wick...
the original tinsel also had heatshrink around it too...
Old Nov 14, 2005
booba5185's Avatar
well either way i bought a new one, i am very good at soldering
there was no heatshrink on the leads when i bought it, i tried wick, normal wire, wick wrapped with no solder, wire with no solder, made it longer, same length, u name it, i did it.
I gave the sub to my friend who is having the same problem while i am pointing and laughing about it
Old Nov 15, 2005
superspec's Avatar
superspec is an unknown quantity at this point
heres an idea,send it back for defects in craftsmanship.even out of warranty most companies will fix things like that.
mrwhos
Aug 11, 2015 02:03 AM
carid
Aug 8, 2015 05:05 PM
jpandjf
Aug 3, 2015 05:02 PM
Nalmonte
Jul 22, 2015 09:08 AM
