6x9" help
Old Feb 6, 2002
avenger's Avatar
avenger is an unknown quantity at this point
6x9" help
crutchfield is messed up I think. The rear deck houses 6x9's, but crutchfield says most of them wont fit...... anyone come across a 6x9 that wont fit the rear deck?
Old Feb 6, 2002
genterara's Avatar
genterara is an unknown quantity at this point
actually, lots of 6x9ers dont fit, some of the ones crutchfield say that wont fit may instead rub against the trunk springs
search this forum
Old Feb 6, 2002
Hefe's Avatar
Second Place is the First Loser
Hefe is a jewel in the roughHefe is a jewel in the roughHefe is a jewel in the rough
Yeah they will rub against the trunk springs....... 6x9's do fit in the back...... Just the mounting depth for those is small
Old Feb 6, 2002
Amphiprion's Avatar
Amphiprion is an unknown quantity at this point
Unsnap that clip that holds the trunk springs together at the center of the trunk.....it will give out a little bit more clearance.
Old Feb 7, 2002
Rebew1's Avatar
Rebew1 is an unknown quantity at this point
I don't see why Honda went to the trunk spring. On the 92-95 civics they used shocks. I think that I might have to do a little disfiguring. My Kappa's fit and they are 3 1/8" depth. Tight fit though.
Old Feb 7, 2002
genterara's Avatar
<< I don't see why Honda went to the trunk spring. On the 92-95 civics they used shocks >>
maybe its cheaper, or people had less problems with shocks
Old Feb 11, 2002
Rebew1's Avatar
I'm sure that it is cheaper, seeing how everything else is. The only thing I don't like is how much plastic newer cars have.
Old Feb 13, 2002
2K1SilverHX's Avatar
2K1SilverHX is an unknown quantity at this point
For another idea... I made panels (1/2" mdf) to fill the spaces for the 6"x9"s and put Boston 6.5" coaxes in their place (cleaner)... You could do that...
Old Feb 13, 2002
RedLiNeD2k1's Avatar
RedLiNeD2k1 is an unknown quantity at this point
i changed my rear deck speakers also...i installed two 6x9 220w pioneer speakers the fit perfect and the depth for is just enough so it doesnt touch the trunk springs
Old Feb 14, 2002
avenger's Avatar
I now have Polk dx9's in back, fit fine [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Mar 3, 2002
GeNoZiDe's Avatar
GeNoZiDe is an unknown quantity at this point
my 6x9 xplodz barely fit in the back!!
it was super tight!!!!! would ve been pissed if they didnt fit though i had to take off the whole back panel to get those stupid stock 6x9z out!!
