Mounting a PDA
Old Oct 11, 2005
Aerodeck's Avatar
Aerodeck is an unknown quantity at this point
Mounting a PDA
hiya
I have a Honda Civic (UK right hand drive)
I want to mount my PDA
Its quite heavy so the mounting must be strong, i use it for SatNav.
I used to have a window mount (long arm with rubber sucker) but that used to fall off every week.
Could people post picture of their mobile phones / PDA's mounted in their civics. Also any sujestions/coments welcome.
Thanks
Old Oct 11, 2005
LowSky's Avatar
I spend way too much time on this website
LowSky is an unknown quantity at this point
what you can do is put a piece of velcro on the back of the unit and on your dash and stick it that way...
or get an earth magnet and some some double side tape
it may look ugly but it would work
Old Oct 11, 2005
MoniraInc's Avatar
MoniraInc is an unknown quantity at this point
i was looking for a mount to do the exact same thing. I have a dell axim though. lowsky has a good idea but i'd prefer something cleaner.
Old Oct 11, 2005
Aerodeck's Avatar
yer, i'm not sure if a magnet would hold the weight of these PDAs...
Old Oct 11, 2005
Albo's Avatar
Albo is an unknown quantity at this point
I bought a PDA mount for my MP3 player with a sucker but don't like the look of it stuck to the window and I wanted it in front of my gear lever so I "suckered" it to the bottom of my ashtray. The ashtray base is a matt finish though so I needed to give it a couple of coats of clear lacquer to make it stick.
Get the PDA mount off ebay like the one below - they have good suckers and don't worry about it being too heavy, my iRiver's fairly hefty and it holds that fine.
Old Oct 11, 2005
Albo's Avatar
forgot to say - I also put a velcro pad on it to make sure it aint goin' anywhere!
Old Oct 11, 2005
Aerodeck's Avatar
yer, thats like the one i have now, but like you, i didn't want it on my window, the sucker is very strong but after a week i'd have to re-attach it to the window. Might look into your ashtray idea....
I think my honda has about 6 cup holders and no phone holder.... go figer
Old Oct 11, 2005
MegaHurtz's Avatar
do they make one that clips on your vent?
Old Oct 11, 2005
ajhdragon's Avatar
7thgens official a$$hole
you could get a pda bracket and then drill hole in it an put 2 small screws in it, then drill into the dash and faster the screw from behind if you really want it to not go anywhere.
Old Oct 11, 2005
diskreet's Avatar
if you have the time/money/patience, it would look awesome if you fiberglass a new docking station for the thing in your car, that way you can also charge it while driving!
Old Oct 11, 2005
Albo's Avatar
the one i mentioned above comes with a vent attachment option.
Old Oct 12, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
i dont know if they have them over in the uk, but where i work at we use bracketrons to mount everything in cars from ipods to sat tuners to pdas. They can be modified to mount just about anywhere.
http://bracketron.com/xmain/products.php
Old Oct 14, 2005
Albo's Avatar
Never seen anything like bracketron in the UK before - pretty good idea though. Only on ething I wanted to be able to do with the mount is to be ablet to completely remove it leaving no clues it was there. Don't like the idea of screwing into the dash or something.
Old Oct 14, 2005
SimonTek's Avatar
SimonTek is an unknown quantity at this point
I will design a pda holder for trade of UK tail lights.
Old Oct 14, 2005
usually we screw the bracketron behind the dash so when its all assembled you cant see where its mounted to. Makes for less headaches when the customer wants it removed.
Something like this might work better for you. http://xmradio.com/catalog/product_d...type=Accessory
it would have to be modified to hold the pda, but could probably be done
Old Oct 22, 2005
Albo's Avatar
This is what I did with the PDA holder above. it's suckered onto the bottom of the ashtray. Works fine.
ID:	61408   Click image for larger version
Old Oct 23, 2005
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
not a bad way of getting nicer tails
Old Oct 23, 2005
LowSky's Avatar
Aero's got a hatchback tails wont fit your coupe... but maybe aero can buying for us....hmmm
mgrantaz
General
May 2, 2022 05:40 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
twd000
Oct 4, 2015 12:52 PM
jackoncruzpr
Sep 29, 2015 07:59 PM
FistRock
Sep 4, 2015 08:00 PM
