component speakers
Old Sep 29, 2005
RS4DUKE's Avatar
RS4DUKE is an unknown quantity at this point
component speakers
hey guys i have to sets of fanatic p components (one set in the front and one set in the rear). My question is if i want to get more low end in the rear without adding subs can i just disconnect the rear tweeters from the crossover and set the rear mid ranges to low pass filter?
Old Sep 29, 2005
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
i don't think the midrange speaker in a component set is designed for low frequencies.
Old Sep 29, 2005
jay78's Avatar
jay78 is on a distinguished road
i agree
Old Sep 29, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
I dont think u understand a x over....
It sends the bass/midrange requencies to the speaker and it send the higher frequencies to the tweeter so if u disconnected ur tweeter u would just be getting sound that wasnt as clear b/c u would b missing some signals. even if u changed the x over it might seem lounder (bass) but it would actually be the same and sound shittier as a whole. Just amp those things if u want more bass
Old Sep 29, 2005
MegaHurtz's Avatar
lowpassing the speakers would not make them play lower/louder... it would just filter out the higher frequencies
Old Sep 30, 2005
82801BA's Avatar
82801BA is an unknown quantity at this point
If you disconnect the tweeter(or any speaker BEHIND crossover) your amp will produce significantly less power.....
Old Sep 30, 2005
82801BA's Avatar
And I don't think much speaker can do low-end bass unless you can tune it to keep up with the resonance of the car to boost low-end, which rear deck is not a good option......
Old Sep 30, 2005
RS4DUKE's Avatar
wow, i guess i am way behind on how components work, thanks for the info guys im just going to leave it as it should be
Mad Dog Tannen
Oct 19, 2016 08:12 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Gsxtacy
Sep 12, 2015 01:09 AM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
redcloud
Sep 7, 2015 01:45 PM
