Need help with 02 civic LX install
Old Sep 26, 2005
soltex's Avatar
soltex has a little shameless behaviour in the past
Just got my deck. Cant figure out how to open the factory radio. The DIY is for only 04. ANy links or how to take it apart.
Old Sep 26, 2005
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
pop out the piece under the dash that holds the 12 volt socket. Then you see 2 screws going through a silver bracket. Remove these. Then get your fingers under and behind that spot and pull towards you and up a little. The whole console will pop out with the vents, radio, and climate control. Unplug everything and remove the whole thing. Then do your thing with the radio.
Old Sep 26, 2005
soltex's Avatar
ok got it
Old Sep 26, 2005
cg95660's Avatar
Wanna see a donkey show?
cg95660 is an unknown quantity at this point
Originally Posted by soltex
hmmm 2 pieces under the dash. i cant put my finger under there tight spot. Right below the 12volt
lol never mind you got it!
Old Sep 26, 2005
dma001's Avatar
dma001 is an unknown quantity at this point
You need to get a good grip on it, then pull. It takes a little force, but it should pop right out.
Old Sep 26, 2005
dma001's Avatar
I used a smooth-edged butter knife to pop the clips out.
Old Sep 26, 2005
soltex's Avatar
Awsome got the wiring and the deck installed was pretty easy. Now where should i direct the RCA and the remote wires/
Old Sep 26, 2005
cg95660's Avatar
I actually pulled the whole center console and ran them under the carpet and bottom back seat to the trunk. It took a bit of wrasslin but it came out good.
Old Sep 26, 2005
dma001's Avatar
As I am sure others have mentioned, always run the RCAs and power cables down opposite sides of the car from each other (to prevent interference).
Old Sep 26, 2005
soltex's Avatar
ok installed everything, deck works
. But the amp turns on but the SUBWOOFER ARE NOT SO LOUD. Dont know. They are not even loud. I can barely hear them. ANy idea whats wrong.??? All of the wires are good and double checked. I mean the amp turns on but the subwoofer is barely i can hear the boom boom. Car speakers works great. Help would be great
Old Sep 26, 2005
flyguy050's Avatar
flyguy050 is an unknown quantity at this point
First check the gain...turn up the gain until it is loud enough but not rumbling....second option is head unit. Fine tune your head unit with the bass and sub settings...also if you have a rockford amp make sure the bass **** is connected...for whatever reason on rockford amps the bass **** makes a big difference, even if it is not turned up, it just has to be plugged in. Finally if all that is good and its still not loud...the ohm level on your sub(s) are probably wired at too high. Get an ohm/volt meter and stick it in the terminal on the box (black to negative, red to positive obviously), if the ohms read higher than 6 or 8ohms, you need to put them in parallel to cut the ohms in half.
Old Sep 26, 2005
flyguy050's Avatar
Pretty much if NONE of that works, the amp might not be grounded well or your battery sucks or you just have a sucky system altogether.
Old Sep 26, 2005
soltex's Avatar
Suck well. Dont know about that. Got a 670Mp Pioneer and a Kenwood 1800Watt amp. Will try it tonight.
Old Sep 26, 2005
soltex's Avatar
hmm well i just had my friend hold it ground wire to the TRUNK LATCH. That may be problem. Had to go to work so didnt get the time to test it out again.
Old Sep 26, 2005
MegaHurtz's Avatar
search. locked.
bsmiley
Apr 27, 2015 01:27 PM
chgofirefighter
Apr 18, 2015 08:08 PM
toastyghosty
32
Dec 26, 2001 02:03 AM
aZnVoYCe
Dec 7, 2001 12:41 AM
SneakerPimp
Nov 5, 2001 10:49 PM
