Need Help ASAP
Old Sep 22, 2005
Cptn. Slow's Avatar
Formerly efil on evol on
Cptn. Slow has a spectacular aura aboutCptn. Slow has a spectacular aura aboutCptn. Slow has a spectacular aura about
Need Help ASAP
I disconnected my battery while working on some wiring and now whenever I try to reattach the negative terminal (w/ positive attached) the alarm goes off and won't stop. It's not the factory alarm, but I don't know the brand.
Please save me from my stupidity.
Old Sep 22, 2005
01redJDM's Avatar
01redJDM is on a distinguished road
so??? mine does that too everytime I reattach my battery. just attach ur battery and when the alarm goes off, turn it off!!!!!
Old Sep 22, 2005
Cptn. Slow's Avatar
it won't respond to the remote
Old Sep 22, 2005
lol it shouldn't do that when the batery is hooked up again. If you have a backup battery, it might have a blown fuse or something.
Old Sep 22, 2005
jgrow44's Avatar
jgrow44 is an unknown quantity at this point
mine does that too. try putting the key in, turning it two clicks and then try the remote with the key still in the ignition. works for me.
Old Sep 22, 2005
01redJDM's Avatar
Thats messed up man, mine just goes off with the remote. if u have a back up battery u might want to try using the key that comes with it to turn it off
Old Sep 22, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
Have you tried to locate the kill switch for the alarm? There should be a hidden switch somewhere in the car where you can turn the alarm off. In our cars, the most common, and easiest loaction, it up above the kick panel/dead pedal area. Should be located somewhere behind or near to the hood release lever, at least that's where most shops would install it, as it's easy to mount to.
Old Sep 22, 2005
Cptn. Slow's Avatar
Yeah it's in there I just am going to be a considerent neighbor and wait til the morning. Thanks everyone for the help I'll let you know how it goes.
Old Sep 22, 2005
ZapThyCat's Avatar
ZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to behold
Wow. Wish you lived near me
Old Sep 22, 2005
01redJDM's Avatar
oh damn neighbours, I bought air tools but was never able to use them.
Old Sep 23, 2005
Cptn. Slow's Avatar
Thanks everyone for your help. I was able to get everything under control finally. Ended up removing the ground on the siren to buy me some time. Turns out I had to use the kill switch as PopcornPlaya suggested.
