need cig lighter part.
ok i tracked it down to this page. but im having a hard time
i own a DX with the black interior.
where the cig lighter cover is. abovet eh lower pocket. i cut a hole in it for a mod a while back and then it fell through. i am needing a replacement for that part. i believe i need to buy the whole assembly pocket and everything. im taking mine out tomorow to find out for sure.
anyone know what part im talking about? only part damaged was the cig cap. and the black flat part to the left of the. the body of the piece and the pocket are intact..
help
http://www.hondaautomotiveparts.com/...SENGER+SIDE%29
thanks!!
help
thanks!!
ok lookign at it i think i need piece 16.
but i also need the piece that fills in the hole on the left side of the pice. little 1x1 hole for a switch or something that is simply plugged
and i need the cover that flips down over the cigerette lighter... help
Electric Boogaloo...
ok. now on mine i have a lil square thing beside the cig lighter that pops out. as i have nothing in it. itsjust a plug of sorts like whats over your change tray thingy. will that come with part 16 or is it extra?
On the stock one the piece is in there. The reason it's there is for the fog light switch in the OEM fogs. If you have OEM fogs, that's where the plug goes. If you don't, the piece will still be in there, not punched out. It's a plastic square that's got a perforated line around it, there are 4 places (one on each side) where it's connected to the main piece. It'll be in the replacement one.
tavisc
Sep 15, 2015 07:46 PM
Bricoleur
Sep 9, 2015 12:23 PM
hatch90
Sep 3, 2015 08:45 AM
Dave1984
Jul 22, 2015 06:10 PM
